THanks. I rebooted and the process list looks much the same. I just went back to the older beta, since it did the same thing but took about 4 days for the slowdown to occur.
I am guessing that one of the closed source pieces that you updated might be causing a problem ???? I don't know.
THanks
I've seen a few reports here and there from people also experiencing performance degradation over time, with various firmware versions (not just the newer 4.3xx builds, but also the previous 4.2xx builds), especially with the RT-AC66U. Not all could share the same cause however, as there can be many reasons for this to occur. What router model do you have?
In your case I don't think it's related to running processes, unless you see your free RAM abnormally low when the issue start to occur. You could monitor that as well as CPU usage through the Sysinfo page next time you start experiencing wifi performance issues. But since the issue seems to occur specifically on wifi, I suspect it's more related to the wifi driver or settings than to the running processes.
One temporary workaround you could do is schedule a nightly task that would restart the wireless service in the middle of the night (probably no need to restart the whole router). Not a real solution, but it might at least help in the mean time.
