Release Asuswrt-Merlin 3004.388.6 is now available
Clients are OK.
AiMesh node Icons- not OK
AiMesh Nodes (usually showing Icon of the router itself, now it does not, not sure what causing it).
Okay, I don't use an AiMesh node, but the icons also work in the AiMesh option :
This "page", also fine.
In normal way, it would show you icons of the AiMesh nodes in the AiMesh Nodes section in home page, now it shows generic router ICON.
I've just looked, but the page is empty because I don't use it... you'll have to ask someone else who uses Aimesh :
@RMerlin , not sure if it is related, but I did everything from my side, and cannot fix it.
Nothing in 388.6_2 touched any of AiMesh or the client list.
merlin@ubuntu-dev:~/amng$ git log --oneline 3004.388.6..3004.388.6_2
bc3c8c3285 (HEAD -> master, tag: 3004.388.6_2, origin/master) Bumped revision to 3004.388.6_2
68d8100705 Merge pull request #840 from dave14305/rstats
f3a42801d4 dnsmasq:  Fix error introduced in 51471cafa5a4fa44d6fe490885d9910bd72a5907
e9fea56583     Fix spurious "resource limit exceeded" messages.
0af2da8d5e Revert "dnsmasq: move "resource limit exceeded" to DEBUG priority"
95baaf2574 dnsmasq: move "resource limit exceeded" to DEBUG priority
140e2f975d Updated documentation
e203a688db Bumped revision to 3004.388.6_1
53d95dcb02 dnsmasq: updated to 2.90
9123a70a55 webui: properly hide Hostname row when disabling DDNS
b6ffe7cf25 webui: hide jffs_format setting by default
9140f7920e build: enable LACP on the XT12
a315e0173c webui: remove rstats week option
My guess is the icons disappeared because of the reboot, not because of the firmware upgrade.
EDIT:
Did resolved on its own.
Thank you!
It seems something with connectivity to an ASUS domain is related with that (Didn't know it)...
Not sure if it can be resolved on its own, but I preffered to say it.
Maybe it is something that will be resolved later on by itself.
Just like that, boom, did not do anything, and it is restored on its own.
Not sure what even caused it in the firsr place.
Thank you, as usual, @RMerlin for your hard work.
Oh, just got the half loaded page with GitHub (no matter the browser or device), and after a few minutes loaded fully...
GitHub here loads and works just fine.
Any special link to check?
Trully fine so far besides that resolved-icon issue.
It is website code
<div class="model_icon web" style="background-image: url("https://nw-dlcdnet.asus.com/plugin/productIcons/ROUTER-MODEL.png");'
It will fix itself when the page is displayed and the router and your browser connects to it.
No, anything on it, It happened an hour ago or so. My link was this one for MPC-HC.
But I also noticed many pages start half loaded and then after a pose load fully (like this one)... 🤔
It is website code
It did resolved on its own, back to life without special intervention.
Thank you for your effort!
Updated from beta to RT-AX86U_3004_388.6_2 with no issues.
For those having icon issues, try clearing your browser cache and/or a different browser.
This won't help when the site providing the icons is offline ;)
Just updated, all good except I had to restart my mesh node, which was a bit of a pain as I had to wander through to the other side of the house in my underwear and got that weird look from my daughter as I crossed the landing as she was also still wandering around in the middle of the night as well for some reason.
