Release Asuswrt-Merlin 3004.388.7 is now available
Failure.
Just bought a new RT-AX86U Pro out of the box today and it automatically updated to Asus firmware version: 3.0.0.4.388_23565
Tried to flash with: RT-AX86U_3004_388.7_0_pureubi.w
Error: "Firmware upgrade unsuccessful. This may result from incorrect image or error transmission. Please check the version of firmware and try again."
Any help would be most appreciated. I used DD-WRT on my last Asus and want to try Merlin on this new one :(
Failure.
You need the file that matches your PRO model - look for the PRO one: RT-AX86U_PRO_3004_388.7_0.zip
Failure.
Oops got the pro version now and it worked. My bad.
Slick dirty upgrade from beta 2 to final...nice job, Eric!
Dirty upgrade to 3004.388.7 on all supported units. All stable and running smoothly.
Thanks for more excellent firmware.
After a long testperiod on alpha and short testperiod on beta I am "dirty" on 388.7
Everything is up and running as expected.
THANKS to everyone for testing and BIG THANKS to RMerlin!
  • Like
Reactions: MDM
Dirty upgrade from the beta and I think I have a problem. I cannot stream media from my STB to my Android tablet, something I do every morning while I wake up. I can access OpenWebif on the box in a web-browser, I just can't stream. I've rebooted both devices as well as the router and still the same. I'm going to do a reset/rebuild and see what happens.
I know, not like me to have a problem with a release.
I just did a dirty upgrade to 388.7
I tested a stream from my NAS to Lenovo P12 Pro tablet and had no issues.
What STB is it? I ´ve got a VU+ with openvuplus 3.0 and openwebif. Streaming with VLC at PC and dreamdroid at Android devices ok.
Did you restart your stb after updating your router?
STB, Router and tablet. All rebooted. The box is a zgemma H.2H.
All sorted now after the rebuild, but I've lost a few hours on my uptime :eek:🤪
Thanks @RMerlin
Sadly for me this update doesn't want to play nicely with my router, namely GT-AXE16000
Upgrade from 388.6_2 rog to 388.7.0 rog
All I'm greeted with is "Please Wait, Applying Settings"
I left this run for a good 30-45min, having never come across such a strange issue when updating. All the internet around the home is working fine, without any issues.
So I powered down the router, unplugged power, left it probably for around 20 mins, and then came back to do the same install.
No prizes for guessing what is happening again, all whilst I type this message.
How rather annoying.
EDIT: Would like to quickly add that I have attempted updating with the non ROG version, but the same issue occurs.
All good here on RT-AX88U pro and RT-AX86U pro from 3004.388.6_2 to 3004.388.7
Report after 12h- no issues.
Just working...
Tried to dirty flash from last beta, but something went wrong with updating and after manual reboot (as it said to do after update) it came up with the last beta firmware. Had to reset using the WPS method and got it updated.
