How much time did it take before you see any data?
My took 8 hours before anything appeared.
About an hour or so then I saw readings in the graph.
Okey thanks, maby you have more traffic then I then.About an hour or so then I saw readings in the graph.
fw_nat_loopback=2 working fine for me
love the new Wireless Log page,
but I would prefer same devicenames as in networkmap/clients (if possible)
Thank you very much! Really like the new auto refreshing Wireless Log PageThough displaying the host names is not available in AP mode, it would be nice if the saved name entries of the custom_clientlist could be displayed otherwise.
Noticed that on my RT-AC68u (AP mode) the USB-Application is not available on the left side navigation bar anymore.
Wireless log is rock and roll. What's the thing about the other loopback ? What's different ? Is it only regarding DPI ? Is that Trend Micro thing only for ARM ? It can't be ported, isn't it ?
I know you get this question a lot but do I need to do a reset if coming from 378.50?
Hi Merlin, is the Traffic Analyzer enabled for RT-AC68U in this beta?
no support for SNMP on RT-AC3200 ?
Will there also come a beta or final version for the AC56U with ta and dpi? Especial I like the network protection, it has blocked already several malicious sites.
Hi Merlin,
I just got my RT-AC87U, I'm running an OpenVPN Client on it... A weird thing, in the "Adaptive QoS - WAN/LAN Bandwidth Monitor", the graphs are only showing "UPLOAD" when the OpenVPN Client is enabled, BUT, in the "Traffic Manager - Traffic Monitor" BOTH Uplaod / Download are showing fine with good bandwith speed...
Do you think it's a bug in the "Adaptive QoS - WAN/LAN Bandwidth Monitor" page? Wrong interface monitored or something?
Apps Analysis is working fine, even with OpenVPN Client enabled... Everything is fine except the Download / Upload graph on that page...
Thanks for your help!
Did a test on the NAT loopback. Using the Merlin setting I was unable to connect to my Synology using my external DDNS name.
After I changed over to Asus it came right up.
Need to know which router model you are talking about.
DD-WRT doesn't even have NAT Acceleration so why do you insist on keeping this feature on with Merlin firmware if it's laggy for you?Wow merlin!,
I hope I can get rid of ps4 lag with this one somehow if and when it shows up.
EDIT1:
Ok lets try to fix the ps4 lag without turning off nat acceleration please?
dd-wrt = 3 - 3 1/2 seconds (4 seconds max)) great!
now asus or yours (nat acceleration on)I get 8 seconds!
as you see double.
The latest Asus firmware 3.0.0.4.378.4376 has introduced DPI support for AC56U so I assume this code will soon be merged. In 378.50 it was just experimental using the AC68U wireless driver.Will there also come a beta or final version for the AC56U with ta and dpi? Especial I like the network protection, it has blocked already several malicious sites.
Welcome To SNBForums
