This would be a good read for you and possibly a few others on this threadThank you for that tidbit. I have always been using the Adaptive QOS because I was under the impression that it would actually help us. We use Voip (Google voice), lots of different streaming services and PIA VPN as well. We use the VPN only because our isp seems to throttle YouTube, but the very second the VPN is turned on YouTube suddenly works perfectly even for 8K videos. I have to assume that the isp has some kind of throttling in place. It used to also do it with Netflix, but that somehow remedied itself back in late 2016. Now Netflix just works as it should. I put the Voip QOS at the top position, then streaming video at #2, web #3 and transfers at #4.
Not sure if this is the ideal setup for VDSL 40/5 but that is what I been using for several years now. At this low of throughput should I be even bothering to use QOS?
Someone else just left it for 8 hours and it disappeared on its own.Since the betas, I've had a flashing yellow exclamation mark again. How can I remove it?
You can use afraid.org its a good choise.I'm currently using a no-ip DDNS free service which requires reactivation every 30 days. I had signed up with another free DDNS service "DYNU" but I can't set it up in AX-88U as it's not listed as one of the service under DDNS tab. Can someone recommend a good free DDNS service that is also listed in the AX router for setup? Thanks
Know issue, already fixed locally.
Dec 4 17:31:36 kernel: EMF_ERROR: Invalid interface identifier
Dec 4 17:31:36 kernel: EMF_ERROR: Invalid interface specified to rtport add
Dec 4 17:31:36 kernel: Failed to add EMF rtport entry for (null)
/Tools/OtherSettings/Miscellaneous Options;
New firmware version check(no)
Check for new beta firmware releases(no)
Yes, many settings are not applicable in repeater mode, and therefore are not shown.ahh, that was it on my 68U which is running in Repeater mode. Many options in the gui are not shown including the Wireless Settings when in Repeater mode.
Is that normal when running in Repeater mode?
I simply use the direct link (changing the IP) from my 86U running in Wireless Router Mode.
is WAN - Virtual Server / Port Forwarding working yet in this release?
Is there any way to use the Apply button on the OpenVPN Server page in the meantime (through any browser tricks, etc)? I'd like to avoid having to downgrade to a previous FW version, but I'd also like to get my OpenVPN server running again.![]()
On my RT-AX88U i try to configure a standard openvpn or PPTP, everytime when add a username and psw. after pushing apply button , the psw is change to a weird psw.
So i cant login by VPN :-(
factory reset didnt help.
i even try import a old .config from RT-AC88U with the same result :-(
Any idea what happend ?
Always worked fine.
Welcome To SNBForums
