Asuswrt-Merlin 384.8 is now available
Disable web add-ons, one of them is messing with the DOM, or you have an autofill playing tricks on you.
Unfortunately, web add-ons are not the problem, different laptops and / or phone tried.
also inprivate page does not help. :-(
Nice job! with 384.8_1 :)
On my side the problem with the french UI in the tab Admin / system is solved ,the page is displayed correctly now(FF,Edge) . In general I find that the UI is more responsive than before , maybe its just a placebo effect. :p
Dirty flash from 384.8 , no reset, no reboot.
Is it this commit that made this?
*webui: fix pages broken by some languages having a quote in hostname … 96524a6
https://www.snbforums.com/threads/b...eta-is-now-available.49908/page-7#post-445474
I uploaded a few early test builds. Gathering further feedback before finalizing a point release, so 384.8_2 won't be out for at least a couple of days.
My computer's 5GHz Wi-Fi isn't getting along with 384.8 even after Initializing the router (RT-AC66U B1). Didn't see anything unusual in the router's system log either. Had to revert to the previous stable 384.7_2. I shall try your test build to see how it goes.
Edit: So far it looks like the test is more stable. Not a single drop. Thanks @RMerlin!
On my RT-AX88U i try to configure a standard openvpn or PPTP, everytime when add a username and psw. after pushing apply button , the psw is change to a weird psw.
So i cant login by VPN :-(
factory reset didnt help.
i even try import a old .config from RT-AC88U with the same result :-(
Any idea what happend ?
Looks like Asus now encrypts those passwords...
EDIT:: Have you actually tested it with the password you had entered? Because it seems to work for me, it's just that you can't view the decrypted version on the webui.
Does the password have a template like
$n$_______$___________
No, they use base64 encoding (ABCD==).
The password gets decrypted at the time they write to passwd.openvpn, so the server works fine, it's just that it's no longer possible to view on the webui (unless I start decrypting them and passing a decrypted version to httpd, which would completely defeat the purpose of encryption).
admin@stargate88ax:/tmp/home/root# nvram get vpn_serverx_clientlist
<merlin2>yppqnpAPwftF4W2U+Tjl1A==<merlin>yppqnpAPwftF4W2U+Tjl1A==
(those were temporary test accounts)
Hello,
i have upgraded to 384.8_1 and the issue for french language work now.
All settings is not translated in french but work fine.
One issue for me: I have always alert for new firmware available.
@RMerlin
Hey. Iptables rules are not saved on the latest firmware.
iptables -I INPUT -p tcp --destination-port 51413 -j ACCEPT
iptables -I INPUT -p udp --destination-port 51413 -j ACCEPT
I enter commands to open port 51413, but after restarting the router, these rules disappear and the port becomes unavailable. Who knows how to keep them? Thanks.
@RMerlin
You have to run them from within a shell script to make them persistent between reboots.
firewall-start script event is recommended for your case.
No i can't login,
weird thing happend, when i upload the org firmware (FW_RT_AX88U_30043845247) without factoryreset, i can login with entered passwrd?
Else found this problem with AiProtection, with included bilateral IPS can't connect via NFS from the local network (media player) to a directory on the HDD for the router, the IPS report shows the presence of attack "External Attacks", and Security Alert – "VULN dump Portmapper reconnaissance". If you disable IPS, then connect to the disk via NFS without problems. What could be the reason?
I'm currently using a no-ip DDNS free service which requires reactivation every 30 days. I had signed up with another free DDNS service "DYNU" but I can't set it up in AX-88U as it's not listed as one of the service under DDNS tab. Can someone recommend a good free DDNS service that is also listed in the AX router for setup? Thanks
If you own your own domain, I highly recommend using he.net's dynamic DNS service on a subdomain: https://dns.he.net/docs.html. You can configure it in AsusWRT with DNSOMATIC.com. No need to do anything, and you can set up a subdomain like ddns.yourdomain.com.
Edit: This is off-topic for the thread, mods feel free to delete if appropriate.
3.0.0.4.384.45149 released by ASUS today…...
No i can't login,
Update: just “upgrade” the org firmware with 384.8 (without factory reset) and now i can login with the entered username and password.
Dont understand why or what make the differents, the only thing is that i configure this time the username + psw in org firmware instead configure it on a clean 384.8 ,
but im glad its working again
Don't know if this is a problem? router.asus.com fails on RT-AC86U. 192.168.50.1 works and system log shows these lines...
Dec 3 10:47:24 kernel: pgd = ffffffc0152dd000
Dec 3 10:47:24 kernel: [004b30f4] *pgd=00000000152e1003, *pud=00000000152e1003, *pmd=0000000014807003, *pte=0000000000000000
Dec 3 10:47:24 kernel: CPU: 0 PID: 791 Comm: httpd Tainted: P O 4.1.27 #2
Dec 3 10:47:24 kernel: Hardware name: Broadcom-v8A (DT)
Dec 3 10:47:24 kernel: task: ffffffc01e022b80 ti: ffffffc0153d0000 task.ti: ffffffc0153d0000
Dec 3 10:47:24 kernel: PC is at 0xf6f40aa0
Dec 3 10:47:24 kernel: LR is at 0x26cc4
Dec 3 10:47:24 kernel: pc : [<00000000f6f40aa0>] lr : [<0000000000026cc4>] pstate: 20000010
Dec 3 10:47:24 kernel: sp : 00000000ff86b408
Dec 3 10:47:24 kernel: x12: 000000000008c71c
Dec 3 10:47:24 kernel: x11: 00000000000791e0 x10: 0000000000000001
Dec 3 10:47:24 kernel: x9 : 000000000049f530 x8 : 0000000000000000
Dec 3 10:47:24 kernel: x7 : 00000000004b30e8 x6 : 000000000048d380
Dec 3 10:47:24 kernel: x5 : 00000000004b3260 x4 : 00000000004b30e8
Dec 3 10:47:24 kernel: x3 : 00000000f6dec7a8 x2 : 00000000f6dec7a8
Dec 3 10:47:24 kernel: x1 : 0000000000000000 x0 : 00000000004b30e8
Dec 3 10:47:42 watchdog: restart httpd
Dec 3 10:47:42 rc_service: watchdog 802:notify_rc stop_httpd
Dec 3 10:47:42 rc_service: watchdog 802:notify_rc start_httpd
Dec 3 10:47:42 RT-AC86U: start https:8443
Dec 3 10:47:42 RT-AC86U: start httpd:80
Router seems to be working like it should though.
I am having the same issue. It kicks my wifi devices off while it restarts the service: Log:
Dec 6 10:52:23 kernel: httpd[782]: unhandled level 3 translation fault (11) at 0x0041306c, esr 0x92000007
Dec 6 10:52:23 kernel: pgd = ffffffc015382000
Dec 6 10:52:23 kernel: [0041306c] *pgd=00000000152d9003, *pud=00000000152d9003, *pmd=0000000015013003, *pte=0000000000000000
Dec 6 10:52:23 kernel: CPU: 1 PID: 782 Comm: httpd Tainted: P O 4.1.27 #2
Dec 6 10:52:23 kernel: Hardware name: Broadcom-v8A (DT)
Dec 6 10:52:23 kernel: task: ffffffc01e022b80 ti: ffffffc0153f8000 task.ti: ffffffc0153f8000
Dec 6 10:52:23 kernel: PC is at 0xf6bdfaa0
Dec 6 10:52:23 kernel: LR is at 0x26cd4
Dec 6 10:52:23 kernel: pc : [<00000000f6bdfaa0>] lr : [<0000000000026cd4>] pstate: 20000010
Dec 6 10:52:23 kernel: sp : 00000000ffb07d58
Dec 6 10:52:23 kernel: x12: 000000000008c71c
Dec 6 10:52:24 kernel: x11: 00000000000791e0 x10: 0000000000000001
Dec 6 10:52:24 kernel: x9 : 000000000039a750 x8 : 0000000000000000
Dec 6 10:52:24 kernel: x7 : 000000000038f410 x6 : 00000000003a5d90
Dec 6 10:52:24 kernel: x5 : 0000000000413060 x4 : 0000000000413060
Dec 6 10:52:24 kernel: x3 : 00000000ffffffff x2 : 00000000f6a8b7a8
Dec 6 10:52:24 kernel: x1 : 0000000000000000 x0 : 0000000000413060
Dec 6 10:52:31 watchdog: restart httpd
Dec 6 10:52:31 rc_service: watchdog 790:notify_rc stop_httpd
Dec 6 10:52:31 rc_service: watchdog 790:notify_rc start_httpd
Dec 6 10:52:31 RT-AC86U: start https:8443
Dec 6 10:52:31 RT-AC86U: start httpd:80
bues afternoon, I'm from Chile, I have the AC68U asus, I have updated up to 384.5, at the moment of updating with the next firmware, it remains as factory and it deletes all the configuration, it is done by resetting the equipment again and it does not stop doing anything, just I can do it until 384.5, I would appreciate your help from now thanks, greetings from Chile
