I have been using 3 AC68U routers with the latest merlin firmware ( I use aimesh 386.1_2)
So I started updating the firmware to 386.2
First update went to mesh node nr1, which is wireless. Firmware updated ok.
Second I updated mesh node nr2, which is backhauled by ethernet. This node fails to update. Tried a few times, rebooted, same result: fails to update.
Third updated the main router. Updated fine.
Tried to update mesh node nr2 several times after that and each time it just fails to update.
I get the login screen , put user/pw in, then select update file and it say uploading 0%, this takes a while and it switches back to the screen that has the uploads button on it and nothing happens.
I tried the following things:
removed node and reset the node by pressing reboot button for a while, re-pair the node, then upgrade. fail
removed node and reset the node by pressing pws butotn for a while, re-pair node, then upgrade. fail.
Put node in wireless mode only (disconnected backhaul ethernet cable), upgrade fails.
I used chrome browser and also tried on edge browser. Made no difference.
I know I can upgrade it by resetting it and connecting it directly to my laptop and upgrade the firmware, but why does it not upgrade while in regular use as a node ??? And the other does upgraded just fine.?
Any tips appreciated.
