FlexQoS FlexQoS 1.2.4 - Flexible QoS Enhancement Script for Adaptive QoS
Hey @dave14305 I'm getting this in my logs since turning on igmp support on my AC68U.
Feb 12 14:33:16 RT-AC68U-B790 rc_service: httpd 830:notify_rc restart_qos;restart_firewall;
Feb 12 14:33:16 RT-AC68U-B790 custom_script: Running /jffs/scripts/service-event (args: restart qos)
Feb 12 14:33:34 RT-AC68U-B790 BWDPI: fun bitmap = 4ff
Feb 12 14:33:34 RT-AC68U-B790 A.QoS: qos_count=0, qos_check=1
Feb 12 14:33:34 RT-AC68U-B790 A.QoS: qos rule is less than 22
Feb 12 14:33:34 RT-AC68U-B790 A.QoS: restart A.QoS because set_qos_conf / set_qos_on / setup rule fail
Feb 12 14:33:34 RT-AC68U-B790 custom_script: Running /jffs/scripts/service-event-end (args: restart qos)
Feb 12 14:33:34 RT-AC68U-B790 custom_script: Running /jffs/scripts/service-event (args: restart firewall)
Feb 12 14:33:35 RT-AC68U-B790 custom_script: Running /jffs/scripts/firewall-start (args: eth0)
Feb 12 14:33:35 RT-AC68U-B790 custom_script: Running /jffs/scripts/service-event-end (args: restart firewall)
Feb 12 14:33:36 RT-AC68U-B790 FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=16621) called in unattended mode with 1 args: -start
Feb 12 14:33:38 RT-AC68U-B790 FlexQoS: Applying iptables static rules
Feb 12 14:33:38 RT-AC68U-B790 FlexQoS: Applying iptables custom rules
Feb 12 14:33:39 RT-AC68U-B790 FlexQoS: Flushing conntrack table
Feb 12 14:33:45 RT-AC68U-B790 FlexQoS: Applying AppDB rules and TC rates
Is this a bad thing?
It seems to prevent classes of traffic being loaded in the GUI. If you restart QOS it all works out but still gives this error.
If I don't restart I start seeing these in my log.
Feb 12 14:31:02 RT-AC68U-B790 FlexQoS: QoS state: Classes=0 | Filters=0 | HTB root qdiscs=0
It seems about normal for a 68U on 386.1 with the known Adaptive QoS problems. But this did remind me I wanted to cut down on the number of debug messages with the Classes, Filters and qdiscs. So I've pushed a minor 1.2.1 update to only log one message at the end of the 3 minute startup delay. After 3 minutes, FlexQoS will give up waiting and restart qos for you, so it probably would have resolved itself.
@dave14305 are there changelogs for dev version also ?
Not usually, since develop is always a work-in-progress. The changelog is the Github commit history, or the comparison to the master (stable) branch. Not many big changes at this point. I'm working on how to avoid writing "default" settings to the custom_settings.txt file so we don't waste space there when unnecessary.
Extra kudos to you guys dev'ing UI stuff.... I had fun learning shell over the years and would like to think I've graduated one level (novice maybe?) from noob writing 10 liners. The GUI coding is proving to be even slightly more challenging than when I started out on shell
Hoping someone can shed some light on difficulty installing this script. I'm setting up a new AC86 (replacing a venerable N66) which I purchased primarily for the customisable QoS option (for VOIP). The router is using the latest Merlin firmware, 386.1. Attempting to install the script with or without AMTM results in the WebUI showing the FlexQoS tab however upon opening the tab returns the 404 file not found error. I've made many attempts all ending at the same point. I subsequently installed both the original FreshJR script and YazFi Guest network script successfully, simply to establish if I'd been making a fundamental install error. Uninstalled FreshJR, try again and still the same 404 error.
I've copied the text (please see below) from Putty from the (AMTM) FlexQoS install process which does look odd, however this is way above my pay grade and thought someone could offer some insight why this is/aint happening? many thanks.
Installing FlexQoS...
Checking firmware support...
Downloading WebUI files...
cp: can't stat '/jffs/addons/flexqos/flexqos.asp': No such file or directory
Adding FlexQoS entries to Merlin user scripts...
Adding nightly cron job...
Adding flexqos alias in profile.add...
FlexQoS installation complete!
Not sure if anyone knows this, but I noticed the AX86U has a 'GeForce NOW' QoS setting. I've yet to use it but I'm sure this would not be compatible with FlexQoS correct?
I'll go get smart now and catch up what this is. Thanks
Please run these commands and post the output. Seems you are unable to download the webpage correctly.
grep flexqos.asp /tmp/syslog.log*
ls -l /tmp/flexqos*
df /tmp
ls -l /jffs/addons/flexqos
df /jffs
nslookup raw.githubusercontent.com
which md5sum
date
curl -v https://raw.githubusercontent.com/dave14305/FlexQoS/master/flexqos.asp -o /jffs/addons/flexqos/flexqos.asp
flexqos check
thanks for your assistance. Output as requested..
ASUSWRT-Merlin RT-AC86U 386.1_0 Sat Jan 30 20:22:26 UTC 2021
asus86u@RT-AC2900-0C18:/tmp/home/root# grep flexqos.asp /tmp/syslog.log*
which md5sum
date
flexqos check/tmp/syslog.log-1:Feb 13 03:07:48 FlexQoS: Updating flexqos.asp failed
/tmp/syslog.log-1:Feb 13 03:11:37 FlexQoS: Updating flexqos.asp failed
/tmp/syslog.log-1:Feb 13 03:13:43 FlexQoS: Updating flexqos.asp failed
asus86u@RT-AC2900-0C18:/tmp/home/root# ls -l /tmp/flexqos*
ls: /tmp/flexqos*: No such file or directory
asus86u@RT-AC2900-0C18:/tmp/home/root# df /tmp
Filesystem 1K-blocks Used Available Use% Mounted on
tmpfs 220168 1756 218412 1% /tmp/mnt
asus86u@RT-AC2900-0C18:/tmp/home/root# ls -l /jffs/addons/flexqos
ls: /jffs/addons/flexqos: No such file or directory
asus86u@RT-AC2900-0C18:/tmp/home/root# df /jffs
/dev/mtdblock9 48128 3240 44888 7% /jffs
asus86u@RT-AC2900-0C18:/tmp/home/root# nslookup raw.githubusercontent.com
Server: 192.168.8.1
Address 1: 192.168.8.1 hi.link
Address 1: 185.199.109.133 cdn-185-199-109-133.github.com
Address 2: 185.199.110.133 cdn-185-199-110-133.github.com
Address 3: 185.199.111.133 cdn-185-199-111-133.github.com
Address 4: 185.199.108.133 cdn-185-199-108-133.github.com
asus86u@RT-AC2900-0C18:/tmp/home/root# which md5sum
/usr/bin/md5sum
asus86u@RT-AC2900-0C18:/tmp/home/root# date
Sat Feb 13 13:05:53 CET 2021
asus86u@RT-AC2900-0C18:/tmp/home/root# curl -v https://raw.githubusercontent.com
* Trying 185.199.109.133:443...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- 0:00:05 --:--:-- 0* Connected to raw.githubusercontent.com (185.199.109.133) port 443 (#0)
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: /etc/ssl/certs/ca-certificates.crt
CApath: none
} [5 bytes data]
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
} [512 bytes data]
* TLSv1.3 (IN), TLS handshake, Server hello (2):
{ [122 bytes data]
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
{ [25 bytes data]
* TLSv1.3 (IN), TLS handshake, Certificate (11):
{ [3067 bytes data]
* TLSv1.3 (IN), TLS handshake, CERT verify (15):
{ [264 bytes data]
* TLSv1.3 (IN), TLS handshake, Finished (20):
{ [52 bytes data]
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
} [1 bytes data]
* TLSv1.3 (OUT), TLS handshake, Finished (20):
} [52 bytes data]
* SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
* ALPN, server accepted to use http/1.1
* Server certificate:
* subject: C=US; ST=California; L=San Francisco; O=GitHub, Inc.; CN=www.github.com
* start date: May 6 00:00:00 2020 GMT
* expire date: Apr 14 12:00:00 2022 GMT
* subjectAltName: host "raw.githubusercontent.com" matched cert's "*.githubusercontent.com"
* issuer: C=US; O=DigiCert Inc; OU=www.digicert.com; CN=DigiCert SHA2 High Assurance Server CA
* SSL certificate verify ok.
} [5 bytes data]
> GET /dave14305/FlexQoS/master/flexqos.asp HTTP/1.1
> Host: raw.githubusercontent.com
> User-Agent: curl/7.72.0
> Accept: */*
{ [5 bytes data]
* TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
{ [217 bytes data]
* Mark bundle as not supporting multiuse
< HTTP/1.1 200 OK
< Connection: keep-alive
< Content-Length: 88800
< Content-Type: text/plain; charset=utf-8
< Cache-Control: max-age=300
< Content-Security-Policy: default-src 'none'; style-src 'unsafe-inline'; sandbox
< ETag: "eff4e509967d5e19b1eab627badbb89ccc00fb52b834c0ee659a95c8573cdd52"
< Strict-Transport-Security: max-age=31536000
< X-Content-Type-Options: nosniff
< X-Frame-Options: deny
< X-XSS-Protection: 1; mode=block
< X-GitHub-Request-Id: 2928:BA22:6883A5:6F6089:6027C01B
< Accept-Ranges: bytes
< Date: Sat, 13 Feb 2021 12:05:59 GMT
< Via: 1.1 varnish
< X-Served-By: cache-cdg20756-CDG
< X-Cache: HIT
< X-Cache-Hits: 1
< X-Timer: S1613217959.107067,VS0,VE1
< Vary: Authorization,Accept-Encoding, Accept-Encoding
< Access-Control-Allow-Origin: *
< X-Fastly-Request-ID: f431c6fbbd55adb71abe73ae7f76da7dfe196888
< Expires: Sat, 13 Feb 2021 12:10:59 GMT
< Source-Age: 140
{ [5 bytes data]
Warning: Failed to create the file /jffs/addons/flexqos/flexqos.asp: No such
Warning: file or directory
* Failure writing output to destination
1 88800 1 1378 0 0 240 0 0:06:10 0:00:05 0:06:05 5888
* Closing connection 0
} [5 bytes data]
* TLSv1.3 (OUT), TLS alert, close notify (256):
} [2 bytes data]
curl: (23) Failure writing output to destination
asus86u@RT-AC2900-0C18:/tmp/home/root# flexqos check
Please run the install through amtm again. Then run the curl command if it still gives the cp error.
One question, does bandwith per device priority where you can set high and low still dont work as in freshjr script ?
Recently installed Flex 1.2 after upgrading to 386 on my RT-AX3000 and it seems to be excessively limiting bandwidth.
When I run a speedtest from within the ASUS GUI, I get ~8 Up, 180 Down, but when I run a speedtest from a separate browser window, I'm getting ~8 Up/ 70 down. Currently have 8 Up/125 Down as my upload/download limits in the QoS tab.
Any tips for troubleshooting?
FlexQoS v1.2.1 released 2021-02-12
Debug date    : 2021-02-13 16:02:36-0800
Router Model  : RT-AX3000
Firmware Ver  : 386.1_0
DPI/Sig Ver   : 2.0.1 / 2.216
WAN iface     : eth4
tc WAN iface  : eth4
IPv6          : disabled
Undf Prio     : 2
Down Band     : 128000
Up Band       : 8192
Net Control   : 1:10
Work-From-Home: 1:14
Gaming        : 1:11
Others        : 1:15
Web Surfing   : 1:12
Streaming     : 1:13
File Downloads: 1:16
Game Downloads: 1:17
Downrates     :    6400,   19200,   12800,    6400,   25600,   12800,    6400,    6400
Downceils     :  128000,  128000,  128000,  128000,  128000,  128000,  128000,  128000
Uprates       :     409,    1228,     819,     409,    1638,    2457,     409,     409
Upceils       :    8192,    8192,    8192,    8192,    8192,    8192,    8192,    8192
iptables settings: <>>udp>>500,4500>>3<>>udp>16384:16415>>>3<>>tcp>>119,563>>5<>>tcp>>80,443>08****>7
-o br0 -p udp -m multiport --sports 500,4500 -j MARK --set-mark 0x8006ffff/0xc03fffff
-o eth4 -p udp -m multiport --dports 500,4500 -j MARK --set-mark 0x4006ffff/0xc03fffff
-o br0 -p udp -m multiport --dports 16384:16415 -j MARK --set-mark 0x8006ffff/0xc03fffff
-o eth4 -p udp -m multiport --sports 16384:16415 -j MARK --set-mark 0x4006ffff/0xc03fffff
-o br0 -p tcp -m multiport --sports 119,563 -j MARK --set-mark 0x8003ffff/0xc03fffff
-o eth4 -p tcp -m multiport --dports 119,563 -j MARK --set-mark 0x4003ffff/0xc03fffff
-o br0 -p tcp -m multiport --sports 80,443 -m mark --mark 0x80080000/0xc03f0000 -j MARK --set-mark 0x803fffff/0xc03fffff
-o eth4 -p tcp -m multiport --dports 80,443 -m mark --mark 0x40080000/0xc03f0000 -j MARK --set-mark 0x403fffff/0xc03fffff
appdb rules: <000000>6<00006B>6<0D0007>5<0D0086>5<0D00A0>5<12003F>4<13****>4<14****>4
filter change dev br0 prio 2 protocol all handle 827::800 u32 flowid 1:15
filter change dev eth4 prio 2 protocol all handle 827::800 u32 flowid 1:15
filter add dev br0 protocol all prio 2 u32 match mark 0x8000006B 0xc03fffff flowid 1:15
filter add dev eth4 protocol all prio 2 u32 match mark 0x4000006B 0xc03fffff flowid 1:15
filter add dev br0 protocol all prio 15 u32 match mark 0x800D0007 0xc03fffff flowid 1:16
filter add dev eth4 protocol all prio 15 u32 match mark 0x400D0007 0xc03fffff flowid 1:16
filter add dev br0 protocol all prio 15 u32 match mark 0x800D0086 0xc03fffff flowid 1:16
filter add dev eth4 protocol all prio 15 u32 match mark 0x400D0086 0xc03fffff flowid 1:16
filter add dev br0 protocol all prio 15 u32 match mark 0x800D00A0 0xc03fffff flowid 1:16
filter add dev eth4 protocol all prio 15 u32 match mark 0x400D00A0 0xc03fffff flowid 1:16
filter add dev br0 protocol all prio 20 u32 match mark 0x8012003F 0xc03fffff flowid 1:12
filter add dev eth4 protocol all prio 20 u32 match mark 0x4012003F 0xc03fffff flowid 1:12
filter change dev br0 prio 22 protocol all handle 802::800 u32 flowid 1:12
filter change dev eth4 prio 22 protocol all handle 802::800 u32 flowid 1:12
filter change dev br0 prio 23 protocol all handle 804::800 u32 flowid 1:12
filter change dev eth4 prio 23 protocol all handle 804::800 u32 flowid 1:12
class change dev br0 parent 1:1 classid 1:10 htb  prio 0 rate 6400Kbit ceil 128000Kbit burst 16000b cburst 160000b quantum 80000
class change dev eth4 parent 1:1 classid 1:10 htb  prio 0 rate 409Kbit ceil 8192Kbit burst 3200b cburst 9600b quantum 5112
class change dev br0 parent 1:1 classid 1:11 htb  prio 1 rate 19200Kbit ceil 128000Kbit burst 16000b cburst 160000b quantum 240000
class change dev eth4 parent 1:1 classid 1:11 htb  prio 1 rate 1228Kbit ceil 8192Kbit burst 3200b cburst 9600b quantum 15350
class change dev br0 parent 1:1 classid 1:12 htb  prio 2 rate 12800Kbit ceil 128000Kbit burst 16000b cburst 160000b quantum 160000
class change dev eth4 parent 1:1 classid 1:12 htb  prio 2 rate 819Kbit ceil 8192Kbit burst 3200b cburst 9600b quantum 10237
class change dev br0 parent 1:1 classid 1:13 htb  prio 3 rate 6400Kbit ceil 128000Kbit burst 16000b cburst 160000b quantum 80000
class change dev eth4 parent 1:1 classid 1:13 htb  prio 3 rate 409Kbit ceil 8192Kbit burst 3200b cburst 9600b quantum 5112
class change dev br0 parent 1:1 classid 1:14 htb  prio 4 rate 25600Kbit ceil 128000Kbit burst 16000b cburst 160000b quantum 320000
class change dev eth4 parent 1:1 classid 1:14 htb  prio 4 rate 1638Kbit ceil 8192Kbit burst 3200b cburst 9600b quantum 20475
class change dev br0 parent 1:1 classid 1:15 htb  prio 5 rate 12800Kbit ceil 128000Kbit burst 16000b cburst 160000b quantum 160000
class change dev eth4 parent 1:1 classid 1:15 htb  prio 5 rate 2457Kbit ceil 8192Kbit burst 3200b cburst 9600b quantum 30712
class change dev br0 parent 1:1 classid 1:16 htb  prio 6 rate 6400Kbit ceil 128000Kbit burst 16000b cburst 160000b quantum 80000
class change dev eth4 parent 1:1 classid 1:16 htb  prio 6 rate 409Kbit ceil 8192Kbit burst 3200b cburst 9600b quantum 5112
class change dev br0 parent 1:1 classid 1:17 htb  prio 7 rate 6400Kbit ceil 128000Kbit burst 16000b cburst 160000b quantum 80000
class change dev eth4 parent 1:1 classid 1:17 htb  prio 7 rate 409Kbit ceil 8192Kbit burst 3200b cburst 9600b quantum 5112
They don’t seem to work with Adaptive QoS at all, and there is no possibility for them to work if you use the FlexQoS fq_codel option.
Try switching to fq_codel in the FlexQoS GUI options.
Switched to fq and it didn't make a difference. I turned off QoS and retested and got similar results. Tried other clients and they don't seem to have the same problem, which is strange because the throttled client is my desktop that I always use for testing because it gets highest throughout. This may be a 386 induced problem, but not sure yet.
which md5sum
date
Server: 192.168.8.1
/usr/bin/md5sum
CApath: none
} [5 bytes data]
} [512 bytes data]
{ [122 bytes data]
{ [25 bytes data]
{ [3067 bytes data]
{ [264 bytes data]
{ [52 bytes data]
} [1 bytes data]
} [52 bytes data]
} [5 bytes data]
> Accept: */*
{ [5 bytes data]
{ [217 bytes data]
< HTTP/1.1 200 OK
< Via: 1.1 varnish
< X-Cache: HIT
< X-Cache-Hits: 1
< Source-Age: 140
{ [5 bytes data]
} [5 bytes data]
} [2 bytes data]
Check that the /jffs is mounted. You may need to set up for format /jffs and reboot.
