Swistheater
oh it is working now jack i just wanted to let you know about the installing part. me manually moving it down fixed the issue
Since it sounds like it got added as a single line, it would. I suspect you didn't save your file with Unix line endings when you first created itone other issue i noticed was when i uninstalled the ntpmerlin to reinstall it. it also erased my other configurations that were inside the dnsmasq.conf.add file.
I can't find any examples. It looks like <title><#Web_Title#> is what Merlin is referring to at build time.Stupid question, how does one use the proper named entry from the dict file?
grep '<title><#' /www/index.asp | cut -d '#' -f 2
The ntp.conf included with ntpMerlin allows full access from localhost so the most likely explanation was that ntpd was not running.Code:########################################################## ## ## ## _ __ __ _ _ ## ## | | | \/ | | |(_) ## ## _ __ | |_ _ __ | \ / | ___ _ __ | | _ _ __ ## ## | '_ \ | __|| '_ \ | |\/| | / _ \| '__|| || || '_ \ ## ## | | | || |_ | |_) || | | || __/| | | || || | | | ## ## |_| |_| \__|| .__/ |_| |_| \___||_| |_||_||_| |_| ## ## | | ## ## |_| ## ## ## ## v1.2.5 on RT-AC88U ## ## ## ## https://github.com/jackyaz/ntpMerlin ## ## ## ## ## ## DST is currently Inactive ## ## ## ## DST starts on Month 3 Week 2 Weekday 0 Hour 2 ## ## DST ends on Month 10 Week 2 Weekday 0 Hour 2 ## ## ## ########################################################## 1. Generate updated ntpMerlin graphs now 2. Toggle redirect of all NTP traffic to ntpMerlin (currently Disabled) 3. Edit ntpMerlin config u. Check for updates uf. Update ntpMerlin with latest version (force update) e. Exit ntpMerlin z. Uninstall ntpMerlin ########################################################## Choose an option: 1 ntpq: read: Connection refused Press enter to continue... admin@Fatiii:/tmp/home/root# /opt/etc/init.d/S77ntpd restart S77ntpd: Waiting for NTP to sync before starting... Shutting down ntpd... failed. Starting ntpd... already running. admin@Fatiii:/tmp/home/root#
I've re-installed but still it still says: "ntpq: read: Connection refused" any ideas?
The pool's DNS geolocation code is inconsistent. There are pools by continent and country to get around this.Code:# replace the following time servers to the ones close to you # see http://support.ntp.org/bin/view/Servers/NTPPoolServers server 0.pool.ntp.org iburst server 1.pool.ntp.org iburst server 2.pool.ntp.org iburst server 3.pool.ntp.org iburst interface ignore wildcard interface listen br0 logfile /opt/var/spool/ntp/ntp.log driftfile /opt/var/spool/ntp/ntp.drift #leapfile /opt/var/spool/ntp/leap-seconds.list # https://hpiers.obspm.fr/iers/bul/bulc/ntp/leap-seconds.list restrict default limited kod nomodify notrap nopeer noquery # restrictive default IPv4 restrict -6 default limited kod nomodify notrap nopeer noquery # restrictive default IPv6 restrict source nomodify notrap noquery # required for pool directive if using restrictive default permissions restrict 127.0.0.1 # permissive localhost IPv4 restrict -6 ::1 # permissive localhost IPv6 disable auth stats
after reboot it seems better but;
Code:admin@Fatiii:/tmp/home/root# ntpq -p remote refid st t when poll reach delay offset jitter ============================================================================== n1.taur.dk .PPS1. 1 u 49y 64 3 1555838 7779194 7779194 lx.ujf.cas.cz .GPS. 1 u 9 64 3 59.164 -2.425 5500721 *ht-time01.isnic .GNSs. 1 u 6 64 3 105.119 -1.612 7.028 138.68.46.177 ( 90.187.7.5 2 u 10 64 3 202.986 0.820 3478961 admin@Fatiii:/tmp/home/root# ntptime ntp_gettime() returns code 5 (ERROR) time e066b64e.041b21c4 Sun, Apr 21 2019 9:28:46.016, (.016039423), maximum error 16000000 us, estimated error 16000000 us, TAI offset 0 ntp_adjtime() returns code 5 (ERROR) modes 0x0 (), offset 0.000 us, frequency -2.784 ppm, interval 1 s, maximum error 16000000 us, estimated error 16000000 us, status 0x2041 (PLL,UNSYNC,NANO), time constant 3, precision 0.001 us, tolerance 500 ppm,
I'll edit config file and put other servers and try them.
server 0.tr.pool.ntp.org iburst
server 1.tr.pool.ntp.org iburst
server 2.tr.pool.ntp.org iburst
server 3.tr.pool.ntp.org iburst
pool tr.pool.ntp.org iburst
Not to be rude, but this is ridiculous advice. I am just reporting a cosmetic issue as a courtesy to the developer. It is completely unimportant, and my router is functioning perfectly.
Thank you for trying to help.I can only try to help with what I know.
If you think you know more about any specific issue, then please simply ignore my small attempts to try to understand and help, where I am most able to.
It's my understanding that NTP operates solely over UDPYou should mangle ntp 123/tcp too.
My Kodi box (EM7680) could not sync time until I have mangled TCP. Error message was "peer is unsynced". After I mangled TCP it works out of the box.It's my understanding that NTP operates solely over UDP
TCP port 123 was reserved by default by IANA but decidedly not used by NTPDMy Kodi box (EM7680) could not sync time until I have mangled TCP. Error message was "peer is unsynced". After I mangled TCP it works out of the box.
https://www.speedguide.net/port.php?port=123 says NTP uses both TCP and UDP (IANA has assigned both).
I have Kodi running on a couple of Pis using OSMC. Once I've finished moving on Friday, I'll test it out (most of my gear is sat in boxes)My Kodi box (EM7680) could not sync time until I have mangled TCP. Error message was "peer is unsynced". After I mangled TCP it works out of the box.
DST is currently Active
DST starts on Month 10 Week 2 Weekday 0 Hour 2
DST ends on Month 4 Week 1 Weekday 0 Hour 2
Hi Jack
On the menu splash screen it says DST is currently active - when it actually ceased on the 1st week of April. It should say inactive should it not?
Code:DST is currently Active DST starts on Month 10 Week 2 Weekday 0 Hour 2 DST ends on Month 4 Week 1 Weekday 0 Hour 2
DST is active, the start/end is quoted the wrong way around; it started in April and ends in October.
Unless @joe scian is in Australia or other country south of the equator ...DST is active, the start/end is quoted the wrong way around; it started in April and ends in October.
That's just being pulled from nvram. What does your dst settings in the webui look like?Hi Jack
AFAIK my box does not have a real ntpd, but it is from BusyBox (Openntp).I have Kodi running on a couple of Pis using OSMC. Once I've finished moving on Friday, I'll test it out (most of my gear is sat in boxes)
Welcome To SNBForums
