Can you look at the asp source for an unaffected page, and let me know what the title tag includes?
Also, which f/w version are you using?
<title><#711#> - Other Settings</title>
<title>ASUS Wireless Router RT-AX88U - Other Settings</title>
<title><#705#> - NTP Daemon</title>
<title>Please build the WAN connection manually. - NTP Daemon</title>
<title><#705#> - Internet Uptime Monitoring</title>
<title>Please build the WAN connection manually. - Internet Uptime Monitoring</title>
web_redirect_suggestion5_1=Please build the WAN connection manually.
Web_Title=ASUS Wireless Router ZVMODELVZ
lyra_welcome_onboard=Or login to existing Lyra network
<title><#686#> - System Information</title>
<title><#686#> - Other Settings</title>
Firmware Version: 384.8_2
Stupid question, how does one use the proper named entry from the dict file?The <#number#> tags are generated at firmware build time. You cannot use them within third party pages, they will not match on every firmware builds. Use either the proper dict entry name, or a plain text string.
Same if you make a copy of your /www folder and try to reuse it with a different firmware release - strings may no longer match.
## _ __ __ _ _ ##
## | | | \/ | | |(_) ##
## _ __ | |_ _ __ | \ / | ___ _ __ | | _ _ __ ##
## | '_ \ | __|| '_ \ | |\/| | / _ \| '__|| || || '_ \ ##
## | | | || |_ | |_) || | | || __/| | | || || | | | ##
## |_| |_| \__|| .__/ |_| |_| \___||_| |_||_||_| |_| ##
## |_| ##
## v1.2.5 on RT-AC88U ##
## https://github.com/jackyaz/ntpMerlin ##
## DST is currently Inactive ##
## DST starts on Month 3 Week 2 Weekday 0 Hour 2 ##
## DST ends on Month 10 Week 2 Weekday 0 Hour 2 ##
1. Generate updated ntpMerlin graphs now
2. Toggle redirect of all NTP traffic to ntpMerlin
(currently Disabled)
3. Edit ntpMerlin config
u. Check for updates
uf. Update ntpMerlin with latest version (force update)
e. Exit ntpMerlin
z. Uninstall ntpMerlin
Choose an option: 1
ntpq: read: Connection refused
Press enter to continue...
admin@Fatiii:/tmp/home/root# /opt/etc/init.d/S77ntpd restart
S77ntpd: Waiting for NTP to sync before starting...
Shutting down ntpd... failed.
Starting ntpd... already running.
What do you have in the config file?Code:########################################################## ## ## ## _ __ __ _ _ ## ## | | | \/ | | |(_) ## ## _ __ | |_ _ __ | \ / | ___ _ __ | | _ _ __ ## ## | '_ \ | __|| '_ \ | |\/| | / _ \| '__|| || || '_ \ ## ## | | | || |_ | |_) || | | || __/| | | || || | | | ## ## |_| |_| \__|| .__/ |_| |_| \___||_| |_||_||_| |_| ## ## | | ## ## |_| ## ## ## ## v1.2.5 on RT-AC88U ## ## ## ## https://github.com/jackyaz/ntpMerlin ## ## ## ## ## ## DST is currently Inactive ## ## ## ## DST starts on Month 3 Week 2 Weekday 0 Hour 2 ## ## DST ends on Month 10 Week 2 Weekday 0 Hour 2 ## ## ## ########################################################## 1. Generate updated ntpMerlin graphs now 2. Toggle redirect of all NTP traffic to ntpMerlin (currently Disabled) 3. Edit ntpMerlin config u. Check for updates uf. Update ntpMerlin with latest version (force update) e. Exit ntpMerlin z. Uninstall ntpMerlin ########################################################## Choose an option: 1 ntpq: read: Connection refused Press enter to continue... admin@Fatiii:/tmp/home/root# /opt/etc/init.d/S77ntpd restart S77ntpd: Waiting for NTP to sync before starting... Shutting down ntpd... failed. Starting ntpd... already running. admin@Fatiii:/tmp/home/root#
I've re-installed but still it still says: "ntpq: read: Connection refused" any ideas?
# replace the following time servers to the ones close to you
# see http://support.ntp.org/bin/view/Servers/NTPPoolServers
server 0.pool.ntp.org iburst
server 1.pool.ntp.org iburst
server 2.pool.ntp.org iburst
server 3.pool.ntp.org iburst
interface ignore wildcard
interface listen br0
logfile /opt/var/spool/ntp/ntp.log
driftfile /opt/var/spool/ntp/ntp.drift
#leapfile /opt/var/spool/ntp/leap-seconds.list # https://hpiers.obspm.fr/iers/bul/bulc/ntp/leap-seconds.list
restrict default limited kod nomodify notrap nopeer noquery # restrictive default IPv4
restrict -6 default limited kod nomodify notrap nopeer noquery # restrictive default IPv6
restrict source nomodify notrap noquery # required for pool directive if using restrictive default permissions
restrict 127.0.0.1 # permissive localhost IPv4
restrict -6 ::1 # permissive localhost IPv6
disable auth stats
admin@Fatiii:/tmp/home/root# ntpq -p
remote refid st t when poll reach delay offset jitter
n1.taur.dk .PPS1. 1 u 49y 64 3 1555838 7779194 7779194
lx.ujf.cas.cz .GPS. 1 u 9 64 3 59.164 -2.425 5500721
*ht-time01.isnic .GNSs. 1 u 6 64 3 105.119 -1.612 7.028
138.68.46.177 ( 90.187.7.5 2 u 10 64 3 202.986 0.820 3478961
admin@Fatiii:/tmp/home/root# ntptime
ntp_gettime() returns code 5 (ERROR)
time e066b64e.041b21c4 Sun, Apr 21 2019 9:28:46.016, (.016039423),
maximum error 16000000 us, estimated error 16000000 us, TAI offset 0
ntp_adjtime() returns code 5 (ERROR)
modes 0x0 (),
offset 0.000 us, frequency -2.784 ppm, interval 1 s,
status 0x2041 (PLL,UNSYNC,NANO),
time constant 3, precision 0.001 us, tolerance 500 ppm,
Code:# replace the following time servers to the ones close to you # see http://support.ntp.org/bin/view/Servers/NTPPoolServers server 0.pool.ntp.org iburst server 1.pool.ntp.org iburst server 2.pool.ntp.org iburst server 3.pool.ntp.org iburst interface ignore wildcard interface listen br0 logfile /opt/var/spool/ntp/ntp.log driftfile /opt/var/spool/ntp/ntp.drift #leapfile /opt/var/spool/ntp/leap-seconds.list # https://hpiers.obspm.fr/iers/bul/bulc/ntp/leap-seconds.list restrict default limited kod nomodify notrap nopeer noquery # restrictive default IPv4 restrict -6 default limited kod nomodify notrap nopeer noquery # restrictive default IPv6 restrict source nomodify notrap noquery # required for pool directive if using restrictive default permissions restrict 127.0.0.1 # permissive localhost IPv4 restrict -6 ::1 # permissive localhost IPv6 disable auth stats
after reboot it seems better but;
Code:admin@Fatiii:/tmp/home/root# ntpq -p remote refid st t when poll reach delay offset jitter ============================================================================== n1.taur.dk .PPS1. 1 u 49y 64 3 1555838 7779194 7779194 lx.ujf.cas.cz .GPS. 1 u 9 64 3 59.164 -2.425 5500721 *ht-time01.isnic .GNSs. 1 u 6 64 3 105.119 -1.612 7.028 138.68.46.177 ( 90.187.7.5 2 u 10 64 3 202.986 0.820 3478961 admin@Fatiii:/tmp/home/root# ntptime ntp_gettime() returns code 5 (ERROR) time e066b64e.041b21c4 Sun, Apr 21 2019 9:28:46.016, (.016039423), maximum error 16000000 us, estimated error 16000000 us, TAI offset 0 ntp_adjtime() returns code 5 (ERROR) modes 0x0 (), offset 0.000 us, frequency -2.784 ppm, interval 1 s, maximum error 16000000 us, estimated error 16000000 us, status 0x2041 (PLL,UNSYNC,NANO), time constant 3, precision 0.001 us, tolerance 500 ppm,
I'll edit config file and put other servers and try them.
ntp_gettime() returns code 0 (OK)
time e066ba03.1bd03968 Sun, Apr 21 2019 9:44:35.108, (.108646530),
maximum error 51301 us, estimated error 1436 us, TAI offset 0
ntp_adjtime() returns code 0 (OK)
modes 0x0 (),
offset -266.028 us, frequency -2.821 ppm, interval 1 s,
status 0x2001 (PLL,NANO),
time constant 6, precision 0.001 us, tolerance 500 ppm,
Yes, mainly because it was reported that the Client List is not working properly. I need this list to be accurate. I am staying on 384.8_2 until there is a newer release with accurate Client List....any reason why you are not using the latest firmware, 384.10_2?
Not to be rude, but this is ridiculous advice. I am just reporting a cosmetic issue as a courtesy to the developer. It is completely unimportant, and my router is functioning perfectly.I believe that your router may need a full reset to factory defaults..
It should be appended to the end of dnsmasq.conf.addi wanted to report an issue with option 42 when it gets added to the dnsmasq.conf.add file it doesn't get placed on the bottom it gets thrown randomly into the mix with other items on the list causing dnsmasq to fail to start because it doesn't recognize the command.
echo "dhcp-option=lan,42,$(nvram get lan_ipaddr)"' # '"$NTPD_NAME" >> /jffs/configs/dnsmasq.conf.add
Strange - though that sounds like a line-ending issuei only had one command inside the DNSmasq.conf.add file and it placed your new command right beside it instead of below it.
Nope, that's a comment. As a test, remove the line, and re-run ntpmerlin/toggle redirectdoes the #ntpmerlin effect it from being runned properly?
Thread starter | Title | Forum | Replies | Date |
ntpMerlin ntpMerlin compatibility with Merlin 3006.102.3 | Asuswrt-Merlin AddOns | 15 | |
W | ntpMerlin ntpMerlin and timeserverd ntp_ready tests | Asuswrt-Merlin AddOns | 1 | |
D | NTPmerlin config log not found | Asuswrt-Merlin AddOns | 2 |
Welcome To SNBForums
