Rebooting the router now and will leave it for 10 minutes will update
Sometimes the NTP will sync up but most times it will not
#!/bin/sh
Say "Paused for 10 secs"
sleep 10 # Never hurts for nat-start!!!
/jffs/scripts/ntpmerlin ntpredirect # ntpMerlin
In your NAT-start script try this ( once you have installed NTPMerlin back again)
Code:#!/bin/sh Say "Paused for 10 secs" sleep 10 # Never hurts for nat-start!!! /jffs/scripts/ntpmerlin ntpredirect # ntpMerlin
I have a feeling this may fix your problem! Lets know if it does
It was working but it back
This is doing my head in
https://1drv.ms/u/s!ApZr4PK0Md8XthBvv3S9xE-2hIaU
I dont see the "paused for 10 sec" in the log after nat-start executes? also Entware was not found from 9 out of 10 attempts. Do you have storage for stats and config set to usb in ntpmerlin? Maybe you should reformat your USB and reinstall everything from scratch. Starting with amtm then diversion which will install entware. Then ntpmerlin.
What does your nat-start , services-start, and service-event scripts have listed in them?Its still broken even after a reset lol https://1drv.ms/t/s!ApZr4PK0Md8XthIz01Iisdu93i1j
The only thing that bothers me in the log is the use of ISP DNS, but only because I cannot reach it here from USA trying to “dig” against it. Test setting an external WAN DNS like 1.1.1.1 or 9.9.9.9 and reboot.Its still broken even after a reset lol https://1drv.ms/t/s!ApZr4PK0Md8XthIz01Iisdu93i1j
And Cloudflare's 1.1.1.1 and 1.0.0.1 DNS servers may be in Edinburgh or Manchester rather than the Virgin UK's London DNS serversThe only thing that bothers me in the log is the use of ISP DNS, but only because I cannot reach it here from USA trying to “dig” against it. Test setting an external WAN DNS like 1.1.1.1 or 9.9.9.9 and reboot.
Yes, he did say "even after a reset" so I'm assuming that means wiped clean as a baby's bottom.Yes I cant reach them here from Australia. I assume you mean 194.168.8.100 and 194.168.4.100. Also this message WAN_Connection: ISP's DHCP did not function properly. I cant even find any evidence of any of the ops scripts being loaded in the last log. Service-event, nat-start, firewall-start - all missing - Did you reformat the usb and reenable all scripts?
If you are Aussie like me and using an ISP that has dhcp not working, you need to pm jack Cheng on whirlpool forums for the continuous mode instructions, and read into he contious mode theread should help with that issue.Yes I cant reach them here from Australia. I assume you mean 194.168.8.100 and 194.168.4.100. Also this message WAN_Connection: ISP's DHCP did not function properly. I cant even find any evidence of any of the ops scripts being loaded in the last log. Service-event, nat-start, firewall-start - all missing - Did you reformat the usb and reenable all scripts?
Edit: Virgin UK's IP addresses could be anycast so disregard comment
Try defining a routing approach in dnsmasq.conf.addI have set them to 1.1.1.1 & 8.8.8.8 and still NTP still does not want to work
Time set but its taking too long
https://1drv.ms/t/s!ApZr4PK0Md8XthSkmyr45lfulTMM
all i can tell is you have multiple events triggering your time sync multiple times in one session. To me it appears to be associated with your wan restarting.How are we looking now https://1drv.ms/t/s!ApZr4PK0Md8XthWoxoJu_wd3dhS4
What modem are you using? You maybe having modem issues with your ISP.
Thread starter | Title | Forum | Replies | Date |
ntpMerlin ntpMerlin compatibility with Merlin 3006.102.3 | Asuswrt-Merlin AddOns | 15 | |
W | ntpMerlin ntpMerlin and timeserverd ntp_ready tests | Asuswrt-Merlin AddOns | 1 |
Welcome To SNBForums
