SomeWhereOverTheRainBow
Part of the Furniture
Best wishes to you. Glad it is working. what do you think you did that fixed it?Good morning
Am just happy that NTP is working
A reboot should clear it! OrNoticed my ntp config file was wiped at some point. Today I decided to uninstall and reinstall ntpmerlin using AMTM. While this resolved merlin NTP from no longer working, it created a duplicate 'addons' page within the WEB UI. Is anyone aware of how to correct this without a factory reset...
rm /tmp/index_style.css
ntpmerlin startup
Anyone else seeing a min update in amtm but when trying to update it states "
ntpMerlin: No new version - latest is v2.5.1"![]()
my suggestion is to run UU using amtm.Anyone else seeing a min update in amtm but when trying to update it states "
Last commit was 17 days ago, so there is no update....Anyone else seeing a min update in amtm but when trying to update it states "
Maybe his Amtm directory needs a refreshing, I suggest UU to try to do that.Last commit was 17 days ago, so there is no update....
And they not apply on boot.NTPMerlin VServer ports redirection disappear after, i think, a firewall restart
nope you can just use the re direct, and either winscp to change the time servers to the closet ones to you or nano from command line to do it.Does one need to configure the client for NTP servers using NtpMerlin? I've been using it as is. If so, is there any documentation on how to do it? I didn't find much with a search on this thread. I did follow the link and read some on the NTP pool, but didn't learn how to configure them or if I need to.
TIA, jts
RT-AC86U w/ 384.17, RT-AC68U Aimesh node w/ same, 250/10 cable w/ Netgear CM-1000, Diversion, UiDivstats, Skynet, AiProtection, DoT, Scribe, UiScribe, Connmon, SpdMerlin, ScMerlin, Nsrum, NtpMerlin
logfile /opt/var/spool/ntp/ntp.log
driftfile /opt/var/spool/ntp/ntp.drift
leapfile /opt/var/spool/ntp/leap-seconds.list # https://hpiers.obspm.fr/iers/bul/bulc/ntp/leap-seconds.list
restrict default limited kod nomodify notrap nopeer noquery # restrictive default IPv4
restrict -6 default limited kod nomodify notrap nopeer noquery # restrictive default IPv6
restrict source nomodify notrap noquery # required for pool directive if using restrictive default permissions
restrict 127.0.0.1 # permissive localhost IPv4
restrict -6 ::1 # permissive localhost IPv6
interface ignore wildcard
interface listen br0
pool time.cloudflare.com
ntpmerlin existed before the ntp daemon was added to the firmware (in fact, @kvic originally developed a project for running ntpd on routers). at that time, the benefit was a local source of time sync for devices. since ntpd was added to the firmware, the main differences are the charts. you get a bit more control over ntpd with ntp.conf in ntpmerlin, but for most users that won't be a big dealI used to have ntpMerlin installed on my AX88U. For numerous reasons i decided to Nuke the router and start from a clean base. Something I had never done since I originally set up the router from new. Dirty flashing left, right and centre.
Because of this, I am deciding what to install. In the past i just tried everything but I would like to now take a more informed approach.
To that end, may I ask what ntpMerlin brings to the table in compared to the standard NTP settings in Merlin? One obvious thing I know of are the lovely graphs, but there must me more to it than that.
Thread starter | Title | Forum | Replies | Date |
ntpMerlin ntpMerlin compatibility with Merlin 3006.102.3 | Asuswrt-Merlin AddOns | 15 | |
W | ntpMerlin ntpMerlin and timeserverd ntp_ready tests | Asuswrt-Merlin AddOns | 1 |
Welcome To SNBForums
