Sorry... try (anyone can try it) and you'll see that it's as I say:
Everything has always been in chronological order for me as well.
... and there is not even a "Clear" pages (proposal)
The Trend Micro engine is closed source.
This is what I get. One of the page is not ordered correctly.Sorry... try (anyone can try it) and you'll see that it's as I say:
The first 3 entries, the dates are out of order. The times are in order. (I had to look twice tooYou will have to highlight the records you find in the wrong order it for me, because every single entry on that page also looks in the correct order to me...
The first 3 entries, the dates are out of order. The times are in order. (I had to look twice too)
Sorry for not highlight the records at first. We probably have to wait for signature update, right?You will have to highlight the records you find in the wrong order it for me, because every single entry on that page also looks in the correct order to me...
Is it related to LED setting in Tools->Other Settings->Stealth Mode (disable all LEDs)?I had issue of router not showing Both Wifi LED's i.e. it was hanging on a soft reboot but would boot normally on hard reboot, Factory Reset the Router yesterday night would check the soft reboot again to check whether problem resolved after Factory Reset, The problem occurred after upgrading the current firmware
I'd need to see the content of your ovpn file to have any idea as to what might be causing it. It's definitely not the same issue that was mentioned and fixed in the beta build. My guess is, one of the fields in your ovpn file is too large to fit within the router's internal buffers.
I'm happy to send you a copy of the file but am unable to figure out how to send it to you privately.
just prior (less than a minute!) to the first upload attempt. Hard for me to think this is not related. I do see this message at other times, mostly as I do other configuration updates. Any thoughts appreciated!
So pleasant to see ipV6 working perfectly when a second RT-AC68u is connected to a first '68u in media bridge mode, version 2 of ...380.63 software. I.e. pinging google.com and getting back an ipV6 address, connecting to Time Warner Cable (now "Spectrum") in Cincinnati, OH USA. Thanks, Merlin.Asuswrt-Merlin 380.63_2 is now available for all supported models.
This is a minor update which introduces new graphical charts to some pages, and fixes a few minor issues...
Nov 24 09:04:43 kernel: DROP IN=eth0 OUT= MAC=54:a0:50:e5:42:80:58:8d:09:12:bc:00:08:00 SRC=186.212.125.144 DST=80.220.xxx.xxx LEN=44 TOS=0x00 PREC=0x00 TTL=49 ID=53379 PROTO=TCP SPT=37300 DPT=23 SEQ=1356596734 ACK=0 WINDOW=33700 RES=0x00 SYN URGP=0 OPT (020405AC)
Nov 24 09:06:27 kernel: DROP IN=eth0 OUT= MAC=54:a0:50:e5:42:80:58:8d:09:12:bc:00:08:00 SRC=182.40.86.122 DST=80.220.xxx.xxx LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=14254 PROTO=TCP SPT=48335 DPT=23 SEQ=1356596734 ACK=0 WINDOW=37351 RES=0x00 SYN URGP=0
Nov 24 09:06:47 kernel: DROP IN=eth0 OUT= MAC=54:a0:50:e5:42:80:58:8d:09:12:bc:00:08:00 SRC=159.203.223.167 DST=80.220.xxx.xxx LEN=40 TOS=0x00 PREC=0x20 TTL=246 ID=54321 PROTO=TCP SPT=43580 DPT=5632 SEQ=4008962452 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 1 03:00:12 syslogd started: BusyBox v1.20.2
Aug 1 03:00:12 kernel: klogd started: BusyBox v1.20.2 (2016-11-11 16:43:15 EST)
Welcome To SNBForums
