L&LD
Part of the Furniture
i try to help it but i can not
https://www.snbforums.com/threads/r...10-is-now-available.55742/page-18#post-476657
This post is the way forward. The only way.
Hope to see your contributions soon.
Thanks. That seems probably tied to the fix I did this weekend, which would revert the CA, as well as server key and cert if any of these three were missing.
Was it on Server 1 or 2?
OpenVPN server, there was no change to the client code.
There are a few other minor fixes, like the broken Moviestar support, or the missing tooltip on the Other Settings page.
Code:9410bcd604 (HEAD -> mainline) Merge branch 'master' into mainline ac3190bf98 (master) Updated documentation a3abf470a7 httpd: validate correct variable in websRedirect*() (backport from 384_5948) ce29820072 (origin/master, origin/HEAD) rc: openvpn: only re-generate server CA if it's missing, ignore server key/cert c2d2fd7890 rc: openvpn: increase interface queue length from 100 to 1000 bytes 9f7da28be1 webui: fix typo in local DNS resolution setting's tooltip 8e7045e066 Updated documentation 3dfa990152 webui: set Bandwidth Monitor FAQ URL to old one, new one is MIA on Asus servers 7a783fff91 webui: fix missing space in Wireless Log flags legend 2bc62226a6 rc: reset new firmware notification flag in case update check fails to run post-upgrade 33ab4d7550 (origin/mainline) webui: fix Wireless Client layout for some models without Phy/NSS/BW report capabilities aac833dabd webui: added tooltip to the "Use local caching" Tools setting def11e32da Bumped revision to 384.10_1 1f35105eca quagga: drop obsolete config samples
Ironically: Eric probably made a typo; GitHub passwords require a number, maybe he meant April1_><>?remote: Invalid username or password.
Well - on a RT-AC66U_B1 is still shows the old version (384.9) after an upgrade and reboot. Tried this twice now with the same result. Also - following this, CPU Core 1 stays at 100% either for AGES or for ever. It's still there, quite a long while after the upgrade attempt. Core 2 runs very low (<5%).Asuswrt-Merlin 384.10 is now available for all supported models. The focus of this release was the partial migration to OpenSSL 1.1.1 (not all services can be migrated by me, as some would require Asus to recompile them against OpenSSL 1.1.1).
The highlight:
- Added OpenSSL 1.1.1b in parallel to 1.0.2. The most relevant services linked against 1.1.1:
o httpd (the webui)
o OpenVPN
o In-a-dyn
o Strongswan
o Netatalk
o vsftpd
o net-snmp
o Tor
o wget
The userspace "openssl" tool is called openssl11.- Merged with GPL 384_5640 (RT-AX88U)
- Updated components: OpenSSL 1.0 (1.0.2r), OpenVPN (2.4.7), curl (7.64.0), Tor (0.3.5.8), Strongswan (5.7.2). dnsmasq (2.80-g6799320)
- Fixed Samba compatibility issue with recent Tuxera NTFS driver.
- Fixed NFSv2 support (and enabled on HND models).
- Enhancements to OpenVPN key/certs storage and management
- Enhancements to Classification page, which should be faster, and offer filtering
- Various other fixes and tweaks
Downloads are here.
Changelog is here.
This begs for a reset to defaults and hand configure, after the flash.Well - on a RT-AC66U_B1 is still shows the old version (384.9) after an upgrade and reboot. Tried this twice now with the same result. Also - following this, CPU Core 1 stays at 100% either for AGES or for ever. It's still there, quite a long while after the upgrade attempt. Core 2 runs very low (<5%).
Starting at line 32:What's on line 37?
Does this part mean that the CA I entered (4096 bit) was too long and cut off, rendering it invalid and then replaced by the Asus key?:
i try
i try git push
Username for 'https://github.com': rmerl
Password for 'https://rmerl@github.com':
fatal: Authentication failed for 'https://github.com/RMerl/asuswrt-merlin.ng.git/'
Would it be possible to check for illegal characters and automatically do a substitution?
Not sure if I should start a new thread for this but I'm having an issue with this firmware version and the RT-AX88U. I just got this router and after updating to the latest Asus firmware I then flashed to Merlin. Everything works fine except my 5 GHz radio. I normally use Smart Connect (I know it's known to not work very well but it's always worked fine for me on my RT-AC3200 with default rules. Small house). With smart connect I rarely see any clients connect on the 5 GHz band, they always want to stay on 2.4 GHz. I turned of roaming assistant, beam forming, changed the rule, etc... and no difference. I then tried to separate the 2.4 and 5 GHz, giving them different SSID, the 5 GHz would not even show up on my available network list on multiple devices tested.
I thought it was the router so I flashed it back to Asus firmware getting ready to take it back and boom it worked fine on the factory firmware. I even flashed it back to Merlin again after wiping the router to factory default and had the same issue. I'm currently running on the Asus firmware. Anyone else seen this?
Also noticed the signal strength with the RT-AX88U is a bit weaker with this router then my RT-AC3200, same device same location will show -65 dBm vs -60 dBm respectively. Multiple devices have similar results.
It is recommended to remove all USB devices before flashing firmware.
Unplugged all USB devices and still failed upgrading. The same symptom. Also tried to flash 384.9_0, same failure.
I didn't find related info from System log.
Just did this way, still no luckUnplug all USB devices and reboot the router.![]()
Welcome To SNBForums
