Try reading your OS logs!![]()
Try posting something constructive.
interesting while a little misleading as well.![]()
merlin,
how do you usually get the routers you work on?
do you buy them yourself, company sends them, or does the community fund the purchase somehow?
oh wow. i didnt know you had the 68U already.
the whole intent of the question was to know when you'd get one and how you acquire it.
how long til you get a build up you reckon?
This question has been asked so much that I think Merlin has stopped answering it. I am sure that you must have found the answer already but just in case, Merlin has stated that he awaiting the firmware update from Asus for the RT-AC68U. That update should be issued this upcoming week or the following week. Then it could take a week or so for Asus to post the source code which is what Merlin needs in order to merge his code with the stock firmware. So it will be a week or two at least before there is a Merlin-based firmware version for the AC68U.oh wow. i didnt know you had the 68U already.
Actually, since I managed to at least get my USB3 HDD to work @ 50 MB/s with it, I decided to release a preview build
Consider this as something between an alpha and a beta build. It has received somewhat limited testings so far (I'm not running the AC68U as my main router yet as I need to take it down too often for flashing test builds, and this is a brand new router model), so testing was limited to the router sitting on my living room table, with an Ethernet cable connected to it. I don't expect too much trouble however since the HW is very close to the RT-AC56U.
Even with your firmware, the local to local through external address (with port forwarding) doesn't work when HW acceleration is enabled. As soon as I disable HW acceleration it starts working. Any idea where is this problem coming from?
HW acceleration is in a closed-source module. Only Broadcom has the source code to this, there's nothing that can be done about it.
I added these new findings to my ASUS support ticket. Hopefully they will work with Broadcom to fix it.
i wish asus' firmware didnt reboot the router everytime you make a change to the settings.
i want to keep this router online as long as possible, 7 days now, to see how stable it is long term, but at the same time, i think my port forwarding is screwed up so i want to make changes there.
my privatvpn speeds took a massive hit when upgrading to this router, and now i'm not sure what to do to fix things.
Welcome To SNBForums
