spdMerlin spdMerlin - Automated speedtests with graphs
ow yeah :D
***@router:/tmp/home/root# /jffs/scripts/spdmerlin generate
spdMerlin: Starting speedtest using *** for WAN interface
   Speedtest by Ookla
     Server: ***
        ISP: ***
    Latency:     0.96 ms   (0.01 ms jitter)
   Download:   374.79 Mbps (data used: 169.4 MB)
     Upload:   437.89 Mbps (data used: 720.1 MB)
Packet Loss:     0.0%
 Result URL: ***
/opt/bin/sqlite3: error while loading shared libraries: libncursesw.so.6: wrong ELF class: ELFCLASS32
sed: /jffs/addons/spdmerlin.d/csv/Downloaddaily_WAN.tmp: No such file or directory
head: /jffs/addons/spdmerlin.d/csv/Downloaddaily_WAN.tmp: No such file or directory
awk: cmd. line:1: Division by zero
sed: /jffs/addons/spdmerlin.d/csv/Downloadweekly_WAN.tmp: No such file or directory
head: /jffs/addons/spdmerlin.d/csv/Downloadweekly_WAN.tmp: No such file or directory
sed: /jffs/addons/spdmerlin.d/csv/Downloadmonthly_WAN.tmp: No such file or directory
head: /jffs/addons/spdmerlin.d/csv/Downloadmonthly_WAN.tmp: No such file or directory
sed: /jffs/addons/spdmerlin.d/csv/Uploaddaily_WAN.tmp: No such file or directory
head: /jffs/addons/spdmerlin.d/csv/Uploaddaily_WAN.tmp: No such file or directory
sed: /jffs/addons/spdmerlin.d/csv/Uploadweekly_WAN.tmp: No such file or directory
head: /jffs/addons/spdmerlin.d/csv/Uploadweekly_WAN.tmp: No such file or directory
sed: /jffs/addons/spdmerlin.d/csv/Uploadmonthly_WAN.tmp: No such file or directory
head: /jffs/addons/spdmerlin.d/csv/Uploadmonthly_WAN.tmp: No such file or directory
Entware updates playing havoc today.
opkg install --force-reinstall libncursesw
New button incoming :)
Done, PR ready to go. Just waiting for the AutoBW guys to make sure I haven't broken anything they rely on
Thanks, appreciate it. Also looking forward to the CSV exports!
Updated: I recently installed spdMerlin for the 1st time, but I am not getting any graphs displayed even after a week. I read in another post that manually running speedtest from amtm fixed it, so I tried it, but at the end of its run, it displayed this:
spdMerlin: Starting speedtest using auto-selected server for VPNC3 interface
[2020-04-12 08:04:47.323] [error] Configuration - Couldn't connect to server (Network is unreachable)
[2020-04-12 08:04:47.323] [error] Configuration - Cannot retrieve configuration document (0)
[2020-04-12 08:04:47.324] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[2020-04-12 08:04:47.325] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[error] Configuration - Could not retrieve or read configuration (ConfigurationError)
Error: near line 2: near ",": syntax error
I just realized that my VPN client 3 is not connecting which seems to be causing these errors. The other 2 VPN clients worked with no problem.
I did the installation from amtm. How can I get the graphs to display in the GUI?
I did the installation from amtm. How do I fix these errors, and how can I get the graphs to display in the GUI?
Using a VPN? Is router in Router mode?
I figured out that I was getting these messages with the one VPN client that was not connecting properly. I faked out 16_0 by deleting that VPN link, then Merlin no longer tried to connect on that client and spdMerlin no longer complained. The other 2 clients were fine. I'm also now getting graphs for the WAN and the 2 working VPN clients, so all is good.
@Jack Yaz
Thanks for your awesome work always :)
Link generated by spdMerlin in ssh doesn't work if opened in browser, says Not found, is it supposed to be ok? Or it should work?
Is link a placebo?
@Jack Yaz
Is link a placebo?
It should work. It's generated by the Ookla binary, so if it's broken please report it to them.
v3.4.0 is now available!
Changelog:
NEW: Change in minimum version requirement, see README!
NEW: Support for John's Fork of AsusWRT-Merlin
NEW: Option to toggle data output mode for weekly/monthly charts
NEW: Button to export/download CSVs used for charts
NEW: Add option to toggle time format in CSV exports between Unix and non-Unix time
CHANGE: Raw data output is now the default
CHANGE: Migrated from datasource plugin for ChartJS to D3js library
REMOVED: Legacy WebUI code that would override unused ASP pages
Changelog:
Thanks Jack!
One minor bug: currently option 9 doesn't show if is using Unix or non-unix.
What does
cat /jffs/addons/spdmerlin.d/config
return please?
Edit: I pressed 9 a few times to force a change, and the same result.
