Asuswrt-Merlin 3.0.0.4.372.30_2
First of all thanks Rmerlin for all your great work. I have a quick question. Did you change any of the Wins or Master browser options? In the past if i checked these boxes under the USB server miscellaneous configuration area I could resolve devices on my workgroup by hostname. Since I have upgraded I no longer seem to be able to do this.
There hasn't been any change related to this since 354, unless a change on Asus's side of the code is causing issues.
Make sure everything is within the same workgroup, including the router.
Everything looks correct; I dropped back to 270.26b and everything appears to be working correctly. Perhaps ASUS changed the code on their side. Thanks again for all your hard work :D
Make sure you went with 372.30_2. Also, TAP mode is already known to be broken, and I'm too busy with work to look into it these days (I just worked 20+ hours this past weekend).
Also note that keys must be smaller than 4096 bits now. I had to limit the size of the fields to 3000 characters in a fix to prevent buffer overruns at the nvram level.
Hi RMerlin,
What is the reason "TAP mode to be broken" in 372.30_2? I am using 270.26b and it works perfectly as a TAP server. My understanding is that nothing is changed in OpenVPN between 270.26b and 372.30_2. Am I wrong?
I will need more info about setup and actual error messages from folks having OpenVPN issues, cause TAP Server mode is working fine for me.
Version 3.0.0.4.372
1. Upgraded the wireless driver and supported 5GHz explicit Tx beamforming.
ASUS RT-N66U Firmware Version 3.0.0.4.372
Fixed:
1. Fixed AiCloud vulnerability related bugs.
2. Underline "_" can now be acceptable in device name and computer name.
3. Hide Broadcast option in PPTP VPN server when it is disabled.
4. Fixed multicast IPTV related issues in PPPoE/PPTP/L2TP connection.
5 .Fixed parental control offset issue in IE.
6. Fixed 3G dongle related issue.
7. Hide ASUS DDNS description when selecting 3rd party service.
8. Fixed script error 'invalid argument on IE'
9. Fixed smart sync JS error
10. Fixed JST time zone issue.
Added:
2. Disk scan feature. It is in external USB disk status tab in network map.
3. Support Sandisk Cruzer flash drive with both CD-ROM and flash disk interface.
4. Auto adjust time zone in internet setup wizard process.
5. PPTP VPN server status GUI
6. Recognized .rmvb files as video format in media server.
7. Show more detail information in USB application install process.
IPv6
1. Fixed PPP IPv6 global address retrieval
2. added DHCP-PD option
3. Added LAN DHCPv6 server
4. Added network status GUI.
5. Added option domain name if available
3G/4G dongles
1. Support Yota LTE dongle LU150
2. Support ZTE LTE dongle MF821
3. Support 3G dongle Q110
Cant wait for Merlin's take on this :D
openvpn
Merlin,
In terms of more info on openvpn, I can tell you that I couldn't get a far as attempting to try the tap interface. I couldn't save the keys, certs etc. They were there, but the vpn server would not start. I then proceeded to wipe them, saved them (empty) and put them back in (with no trailing carriage returns or spaces) and it just sat there and would not save and hung the whole interface. I had to ssh in and reboot to get the system back online. I was just _2 on the B1 revision tree.
Merlin,
What type of WAN interface? What do you see in System Log when you try to manually start OpenVPN? Server or Client?
AC66 SC is out of the bag.:cool: And asus .372 firmware for N66u with new wireless drivers released.
http://support.asus.com/Download.aspx?SLanguage=en&m=RT-N66U+(VER.B1)&p=11&s=2
Nice - they also included the Northstar (ARM) source in this tarball (that's why it's so large).
I don't expect to have time to really work on this until next week. This one will require more work than usual as well, as I will have to integrate the ARM environment into the main environment (so far, I had to handle ARM-based firmwares in a separate tree as it wasn't integrated into the build system yet).
Maybe that's a good thing, that gives the rest of us time to check out how the new wireless driver does on 5GHz. That may help you with the decision whether or not to keep the 270 wireless driver for your next release.
Bug?
Samba start after plug in USB.
Enable Share -> Disable Share -> Eject USB disk -> internet off -> ping
Pinging 192.168.1.1 with 32 bytes of data:
Request timed out.
Reply from 192.168.1.1: bytes=32 time=1ms TTL=64
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Reply from 192.168.1.1: bytes=32 time=12ms TTL=64
Reply from 192.168.1.1: bytes=32 time=4ms TTL=64
Reply from 192.168.1.1: bytes=32 time=836ms TTL=64
Request timed out.
Request timed out.
Reply from 192.168.1.1: bytes=32 time=6ms TTL=64
Reply from 192.168.1.1: bytes=32 time=853ms TTL=64
Request timed out.
Reply from 192.168.1.1: bytes=32 time=880ms TTL=64
Reply from 192.168.1.1: bytes=32 time=855ms TTL=64
Bug?
Request timed out.
Request timed out.
Request timed out.
Request timed out.
I don't understand - what problem are you experiencing?
Temporarily being unable to contact the router during the Samba startup is probably normal - the firewall has to adjust its rules.
I recently upgraded from 270.26b to 372.30_3. I didn't notice any issue until my cousin try to access the wifi guest network and got denied. He has no problem access guest network wifi before the upgrade. After doing further troubleshooting, it seems the guest network using the wireless mac filter that I setup for my main wifi. Is there way to disable the mac filter being use by the guest network?
Other than that great work RMerlin!!!
Decided to switch back to 270.26b since there no option to disable the mac filter on the guest network without disable the primary wireless mac filter. Hopefully Asus will address this issue and have separate mac filter for the guest network.
1. Disabling the Samba service
2. Plug a USB flash drive into a USB port
3. SSH terminal: top
will not download , tried 3 browsers , no luck ???
Thanks to RTN user :
httр://dlsvr01.asus.com/pub/ASUS/wireless/RT-N66U_B1/FW_RT_N66U_3004372.zip
httр://dlsvr04.asus.com/pub/ASUS/wireless/RT-N66U_B1/FW_RT_N66U_3004372.zip
