Asuswrt-Merlin 374.42_2 is out
I have one more question for now... what should the physical led on/off button do? It sure doesn't turn on or off my leds...
That's what it will do - turn the LEDs on and off. Works fine here.
As I said, those settings are NOT controlable on the web interface, so they are unrelated to any changes you might have done. They are applied by the firmware that was running last time you did a factory default reset. This is why doing a factory default reset is necessary after an upgrade, to apply updated settings.
USB 3.0 disks can interfere with 2.4 GHz wifi. The option to reduce interference will force the USB3 port to run at USB2 speeds to reduce interference (which isn't always compatible with some USB3 disks).
When I got the router, I updated to latest OEM, did a reset, installed your latest, did a 30-30-30 and that's about it. Should be ok?
Does nothing here. Is there some delay or something? Or do I need to reboot after switching?
i have upgraded to the latest build and have problems with the OpenVPN client 1. I have done a factory reset and upgraded, did a couple of resets before and after the upgade 374.42_2.
This worked okay in 374.41.
Edit:
Finally sorted the issue with a few more factory reset. so no problem any more/
Stopp doing factory resets BEFORE upgrade: This makes no sense as you rest to the OLD firmware settings. :eek:
Just do the reset AFTER upgrading to the new firmware version for the NEW firmware settings! :rolleyes:
Then do the minimum configuration you need to beome operational and immediatly try out your issue. The more settings you change the more diffcult it might be to isolate the problem. :)
Glad to hear that you managed it anyway!
With kind regards
Joe :cool:
...did a 30-30-30 and that's about it. Should be ok?
There is nothing like "30-30-30 reset" on Asus routers! Why people alway think this is there? :rolleyes:
Just to a normal FACTORY RESET and you are fine! :)
There are multiple ways of doing it: Via GUI, via WPS button, ... you can read the details in many forum postings!
With kind regards
Joe :cool:
With kind regards
Joe :cool:
Ok, ok! Take it easy! ;-)
I read in other comments that the LEDs are actually software controlled via the button. Are there some FW settings for the LEDs that could be in conflict?
This is not a major issue, I just want to make sure I don't have a defective unit.
I never did try to turn the LEDs off on OEM firmware as I flashed Merlins right away.
EDIT: With 374.42_0 my LED on/off button did nothing. Now with 374.42_2 it works as it should again. :-)
Maybe just a bug on my side, but nice that it's ok now either way.
Is it worth upgrading to 374.42_2 ? I'm not having any issues with 374.42 build everything is perfect as it should be
ASUS RT-AC66U F/W: 374.42
Samba & Cherokee web server with 42
I have a USB data stick plugged into the USB port and from this I have a samba share across my LAN. I also have cherokee web server running on it which provides an intranet for our home devices. Cherokee is started by a script which runs when the USB data stick is mounted. It all works very well.
Currently, I'm on .40 and I'm looking at moving to .42. I've read there are big changes to samba etc. with 42, am I likely to find I can't get my intranet to work after I upgrade?
Any advice appreciated.
Bob.
If coming from 38_2, I assume a full reset and deletion of old wireless profiles on devices is recommended?
There is no 374.42_2 for the RT-AC66U since it was only meant to address teh Time Machine issue.
Recommended, but not mandatory for this router. Try and see for yourself, you'll see if Wifi exhibits any issues.
Hi guys, Noob here. Just upgraded to 42 and factory reset my N66U. I have Comcast with 105/10. Right now, after playing with different settings, 2.4GHz is getting around 50mbps while 5GHZ is solid at 110mbps. I have tried all channels, but to no avail, is 2.4GH capped at 50mbps?
This is my current setting:
wireless mode: n only
channel bandwidth: 20 mhz
control channel: 11
authentication method: wpa2-personal
wpa encryption: AES
network rotation interval: 3600
Someone said to put max mW value of 200 on "Professional" tab but still doesn't give much improvement. Currently is set at default 80.
please let me know if you guys need more info. appreciate the help on this.
Dual WAN issues
I have a problem with Dual WAN setup in Fail over mode.
Main WAN is PPPoE ("Enable VPN + DHCP Connection" disabled), fail over connection is l2tp (+dynamic private ip to connect to the l2tp server). After startup both WAN connections are up (I can see 1 WAN ip on the Primary WAN and 2 ips on Secondary WAN on the network map).
When I unplug the cable from the main WAN port, both WAN connections get reset. The main WAN connection can't start (cable unplugged), the dynamic ip on the secondary WAN gets renewed, but the l2tp connection doesn't initialize. Here is the full log after I disconnected the cable:
May 18 01:50:56 dnsmasq-dhcp[731]: DHCPINFORM(br0) 192.168.0.103 c8:60:00:9b:5f:8f
May 18 01:50:56 dnsmasq-dhcp[731]: DHCPACK(br0) 192.168.0.103 c8:60:00:9b:5f:8f i7-3770K
May 18 01:51:10 WAN(0) Connection: Fail to connect with some issues.
May 18 01:51:10 stop_nat_rules: apply the redirect_rules!
May 18 01:51:32 rc_service: wanduck 526:notify_rc restart_wan_if 0
May 18 01:51:32 pppd[596]: Hangup (SIGHUP)
May 18 01:51:32 pppd[596]: Terminating on signal 15
May 18 01:51:32 pppd[596]: Connect time 12.2 minutes.
May 18 01:51:32 pppd[596]: Sent 63528976 bytes, received 156470669 bytes.
May 18 01:51:32 dnsmasq[731]: read /etc/hosts - 5 addresses
May 18 01:51:32 dnsmasq[731]: using nameserver 212.1.224.6#53
May 18 01:51:32 dnsmasq[731]: using nameserver 212.1.244.6#53
May 18 01:51:32 dnsmasq[731]: using nameserver 85.21.192.5#53
May 18 01:51:32 dnsmasq[731]: using nameserver 213.234.192.7#53
May 18 01:51:33 pppd[596]: Terminating on signal 15
May 18 01:51:34 stop_wan(): perform DHCP release
May 18 01:51:36 pppd[1291]: Plugin rp-pppoe.so loaded.
May 18 01:51:36 pppd[1291]: RP-PPPoE plugin version 3.11 compiled against pppd 2.4.5
May 18 01:51:37 pppd[1292]: pppd 2.4.5 started by admin, uid 0
May 18 01:51:38 rc_service: wanduck 526:notify_rc restart_wan_line 1
May 18 01:51:39 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp1_vlan3)!
May 18 01:51:39 dnsmasq[731]: read /etc/hosts - 5 addresses
May 18 01:51:39 dnsmasq[731]: using nameserver 85.21.192.5#53
May 18 01:51:39 dnsmasq[731]: using nameserver 213.234.192.7#53
May 18 01:51:39 dnsmasq[731]: exiting on receipt of SIGTERM
May 18 01:51:39 dnsmasq[1314]: started, version 2.69 cachesize 1500
May 18 01:51:39 dnsmasq[1314]: asynchronous logging enabled, queue limit is 5 messages
May 18 01:51:39 dnsmasq-dhcp[1314]: DHCP, IP range 192.168.0.2 -- 192.168.0.254, lease time 1d
May 18 01:51:39 dnsmasq-dhcp[1314]: DHCP, sockets bound exclusively to interface br0
May 18 01:51:39 dnsmasq[1314]: read /etc/hosts - 5 addresses
May 18 01:51:39 dnsmasq[1314]: using nameserver 85.21.192.5#53
May 18 01:51:39 dnsmasq[1314]: using nameserver 213.234.192.7#53
May 18 01:51:46 WAN(1) Connection: WAN was restored.
May 18 01:51:47 dnsmasq[1314]: read /etc/hosts - 5 addresses
May 18 01:51:47 dnsmasq[1314]: using nameserver 85.21.192.5#53
May 18 01:51:47 dnsmasq[1314]: using nameserver 213.234.192.7#53
May 18 01:51:47 zcip client: configured 169.254.217.129
May 18 01:52:12 pppd[1292]: Timeout waiting for PADO packets
May 18 01:53:27 pppd[1292]: Timeout waiting for PADO packets
May 18 01:54:42 pppd[1292]: Timeout waiting for PADO packets
May 18 01:55:57 pppd[1292]: Timeout waiting for PADO packets
If I make the WAN port with l2tp connection the main one, the fail over on the WAN with PPPoE works fine, but the fail back to the main WAN port with l2tp as soon as I reinsert the cable doesn't work either (l2tp doesn't start up).
The value will only take effect if your router is configured for a regulatory region where that power level is permissible.
A doubling of the power level will not make that much of a difference, but it could make a marginal connection better.
control channel: 11
wpa encryption: AES
20 MHz will give you half the bandwidth of the 40 MHz width you are probably using on the 5 GHz band, so this looks normal to me, assuming a dual stream connection.
Tried it, but had to go back to 374.39 on RT-N66u. My USB modems did not work for me on .42.
If you need something me to try something or produce a log, let me know what and how and I will try to do so when I am back home - currently out of town.
Cherokee ac68u
Can't get cherokee to work. I walked though the wiki from Merlin's link. When I get to the step ipkg install cherokee it loads the files then warns it cannot read the cherokee conf file and another cherokee lib file. I Scp'ed into the usb/router and both the filers are there, in the correct locations, and have read write permissions. It's a usb 3 flash drive formatted ext2? Any ideas. Cherokee will not start. I've done the ipkg update as well. I'm puzzled, others don't seem to have this issue. FYI, on the lastest merlin build, ac68u.
