What value does knowing which stratum server you are syncing with add? (i'm unsure, personally!)
self gratification for some. it is more important to know the stratum you have become on each sync with pool.ntp.org with each time sync this value could change depending on how the servers you sync with changes. if this value becomes some crazy off the wall number, that could indicate that your clock is not sync properly with those servers.What value does knowing which stratum server you are syncing with add? (i'm unsure, personally!)
yes@Jack Yaz is there supposed to be two prerouting rules in the vserver section of port forwarding, if you enable NTP intercept?
What ports does yours display if I remember correctly mine was 123, but for some absurd reason my VoIP ata stop working, but yesterday when checking the common script apparently my Entware wasn't working so I had to re Install it.
connmon still uses the old approach and has a heavier dependency on entware. ntpmerlin only needs entware for ntpd nowWhat ports does yours display if I remember correctly mine was 123, but for some absurd reason my VoIP ata stop working, but yesterday when checking the common script apparently my Entware wasn't working so I had to re Install it.
Also thank you, I appreciate it.
@Jack Yaz out of curiosity does the script check if Entware is loaded on boot because I was using your common tool and the graphs bugged out and when I went to re Install it said Entware wasn't present but the NTP graphs were still working ish I just find it strange.
Ahh I understand that thanks because I was wondering if that bugged out on me causing NTP to break which breaks time synchronisation and reboot schedule.connmon still uses the old approach and has a heavier dependency on entware. ntpmerlin only needs entware for ntpd now
I have found a new issueconnmon still uses the old approach and has a heavier dependency on entware. ntpmerlin only needs entware for ntpd now
Jul 7 13:57:34 ntpd[10678]: ntpd 4.2.8p13@1.3847-o Fri May 24 19:54:06 UTC 2019 (1): Starting
Jul 7 13:57:34 ntpd[10678]: Command line: ntpd -pn
Jul 7 13:57:34 ntpd[10680]: proto: precision = 1.373 usec (-19)
Jul 7 13:57:34 ntpd[10680]: getconfig: Couldn't open </etc/ntp.conf>: No such file or directory
Jul 7 13:57:34 ntpd[10680]: unable to bind to wildcard address :: - another process may be running - EXITING
firmware's ntpd? but that should be disabled by ntpmerlin - check in System settings (i think)I have found a new issue
Code:Jul 7 13:57:34 ntpd[10678]: ntpd 4.2.8p13@1.3847-o Fri May 24 19:54:06 UTC 2019 (1): Starting Jul 7 13:57:34 ntpd[10678]: Command line: ntpd -pn Jul 7 13:57:34 ntpd[10680]: proto: precision = 1.373 usec (-19) Jul 7 13:57:34 ntpd[10680]: getconfig: Couldn't open </etc/ntp.conf>: No such file or directory Jul 7 13:57:34 ntpd[10680]: unable to bind to wildcard address :: - another process may be running - EXITING
what could be using said Wildcard address ?
3096 root 1200 S< /usr/sbin/ntpd -n -N -l -S /usr/sbin/ntpd-hotplug -p time1.google.com -p time2.google.com -p time3.google.com -p time4.google.com
Is there an ntpq command that pulls just the strata?
remote refid st t when poll reach delay offset jitter
*_gateway 71.79.79.71 2 u 50 128 377 0.505 -0.533 0.206
-192.168.1.20 216.239.35.8 2 u 105 128 377 2.463 -3.519 0.395
+192.168.1.1 216.239.35.0 2 u 1 128 377 1.884 1.143 0.215
+192.168.1.15 216.239.35.0 2 u 66 128 377 1.999 -1.557 0.450
associd=0 status=0615 leap_none, sync_ntp, 1 event, clock_sync,
version="ntpd 4.2.8p10@1.3728-o (1)", processor="x86_64",
system="Linux/4.15.0-54-generic", leap=00, stratum=3, precision=-23,
rootdelay=39.125, rootdisp=22.357, refid=192.168.0.1,
reftime=e0d65d07.1fc6957f Sun, Jul 14 2019 19:01:43.124,
clock=e0d65d39.2bf8e7ae Sun, Jul 14 2019 19:02:33.171, peer=3932, tc=7,
mintc=3, offset=-0.187356, frequency=-37.413, sys_jitter=1.799138,
clk_jitter=0.989, clk_wander=0.110, tai=37, leapsec=201701010000,
expire=201912280000
ntpq -4 -c rv | grep stratum seems to list only the stratum
Thread starter | Title | Forum | Replies | Date |
ntpMerlin ntpMerlin compatibility with Merlin 3006.102.3 | Asuswrt-Merlin AddOns | 15 | |
W | ntpMerlin ntpMerlin and timeserverd ntp_ready tests | Asuswrt-Merlin AddOns | 1 |
Welcome To SNBForums
