SheikhSheikha
Smooth (dirty) update from 384.12
Aug 1 10:35:00 kernel: Register interface [wds0.0.1] MAC: 0c:9d:92:xx:xx:xx
Aug 1 10:35:05 kernel: wfd_unregisterdevice Successfully unregistered ifidx 0 wfd_idx 0
Aug 1 10:35:05 kernel: wfd_registerdevice Successfully registered dev wds0.0.1 ifidx 0 wfd_idx 0
I do believe though this is problem with the 86U and not related to the Merlin software.
RT-AC66U_B1? That is a model number. The B2 may be a hardware version.Just updated and everything working just fine.
I have two RT-AC66U_B2 which I running aimesh nod(s) but one of them I can't get connected.
I have tried everything I know of.
Uptime 0 days 0 hours 53 minute(s) 3 seconds
Thank you RMerlin.
Cyrillic, of course...Try a different browser. They are written in Cyrillic, and they show up properly for me under Chrome.
My faultRT-AC66U_B1? That is a model number. The B2 may be a hardware version.
My RT-AC66U_B1 upgraded well as well as two RT-AC68U's (upgraded from .12 over Openvpn).
Sent from my SM-T380 using Tapatalk
Thanks for pointing out this change in all of the posts as it impacted some code in x3mRouting. I was able to update the x3mRouting project to accommodate the change for non-HND platform routers to give me a file that contains a list of DHCP static reservations containing the IP address and hostname of each client.
- Note for developers, the dhcp_staticlist format was changed to revert back to the same format as stock firmware (for AiMesh compatibility). The hostname field was moved to a separate variable, dhcp_hostnames. Note that this variable will be stored in a jffs file on the RT-AC86U and RT-AX88U due to limitations on variable length for their HND platform. That means that a backed up config file will not restore these hostnames when restored (but using a JFFS backup will).
<42:03:87:62:E9:7G>SamsungTV<00:76:42:EA:FA:9E>AmazonFireTV
Known issue. Asus removed something (cpu idle) that was causing trouble and it caused the temp to increase about 10 centigrade, I have same as you and mine went up as well.Hmm, AX88U dirty update from 384.12 = +10° CPU temperature.
Thanks again for all your hard work,I'm not rich but I will chip in a little something again for you next versionAsuswrt-Merlin 384.13 is now available for all supported models. The main change of this release is the addition of support for AiMesh (both router and nodes) for those models that are compatible (RT-AC87U and RT-AC3200 are not supported). This release also includes a number of fixes. The highlights:
- AiMesh support for both router and nodes. See the AiMesh section below for more information. Please visit the Wiki for more information.
- Updated RT-AX88U to GPL 384_6210.
- dnsmasq now uses OpenSSL instead of Nettle for DNSSEC cipher operations. This allows dnsmasq to validate a wider range of ciphers.
- Some changes also had to be done to the webs_* variables that are used by the new firmware checks, which might affect script developers that were accessing those variables.
- A number of minor issues were fixed, see the Changelog for details
Please only post in this thread about this specific release.
Downloads are here.
Changelog is here.
Welcome To SNBForums
