[Release] FreshJR Adaptive QOS (Improvements / Custom Rules / and Inner workings)
How does it feel? I used to play with SQM and cake but had hit marker delays. dd-wrt and advanced tomato performed better.
Seems fine to me.....Video streaming and VOIP are the two highest categories on my network. My network is 120mb down and 10mb up.
Anyone that plays PS4 or CoD using this QOS? It looks like the same QOS as Advanced Tomato.
I play cod on Xbox, and I've had pretty good results, I hope that helps,
My shots are pretty on point when I'm with local players.
Cool are you playing bo4? And have you changed anything?
Yes bo4 I set my per packet over head I've been playing with that as of late to get close as possible to the right one, I was capping my bandwidth at 95% and that seems to make it smooth.
Ok cool, I have fiber 100/100. I get around 95/95 mbit. Is it an option for packet over head for fiber?
Don’t think it’s necessary when you have fiber. Correct me if im wrong.
Probably not but give it a go anyway and try setting the bandwidth to 95% also it's supposed to account for the handling of smaller packets and factors that in to the calculations as well as things like pppoe overhead.
If you want is just test it see if it helps them disable it if not.
Hey guys, any idea where FreshJR is and if he is ever coming back?
He was about to work on a project for me several months ago but he seems to have vanished.
Thxx
Thxx
We have to give him more time, he's probably fixing alot of bugs and adding a lot more features I'm going to guess he's probably working on that IPv6 part he was talking about, and from what I remember reading that will take a while.
So I'm trying to enter the Optional Gaming Rule. I've entered my IP address of my gaming PC into the LAN < DHCP server < manual assignment list. Does anything need to be assigned in the Adaptive QoS < Classification < FreshJR (customize) Iptable Rules (ipv4)? Do I just enter the single IP address of that PC or does the CIDR table have to be entered?
EDIT: Also I have a game that all the traffic falls into the Untracked container. Will the gaming rule change things? Also if not would that container be best prioritized at the top of the priority list (it's the main game I play on that Gaming PC) And does the download and upload bandwidth in the Iptable Rules (ipv4) have an effect on prioritized categories?
EDIT2: also how does the CIDR range get passed into the script? I seen the examples but they really don't explain anything unless you've done it before.
Either way should work, plain or with /32 at the end.
My AC68U wan port may be flaky, and, I've had to plug the WAN into LAN4 using "dual wan" with no actual cable plugged into the WAN port now. Internet is working at least. So, my question is, will this script just work as is since I am using LAN4 as the WAN port? Or, will it not work?
It should I'm just not sure if it will automatically detect the interface or you will manually set it.
Yo!
I noticed in the classification that my PS4 uses port 3074 for CoD is listed as XBOX. Does it matter? I mean if the port 3074 is listed as gaming then it should be fine? Or is it anyway to change it
